I have not looked inside any of those devices. Do they use a standard motherboard? If so a motherboard swap could get a serious improvement in performance.
I have an older HP time interval analyzer: HP5370. Originally they were built around 6800 microprocessors. An enterprising guy worked out a transplant that replaced the CPU and memory boards with a Beaglebone black. The update got a significant increase in throughput. The jitter floor is the same (20 pS) but its still hard to get a better instrument. He sold through 50 of his upgrades in a few weeks.
Yes, the motherboard looks quite standard, but I have not even looked to see what processor is in it.
Bob
The SRC2496 came by courier yesterday.
Tonight I plugged it up, plugged in some cheap dynamic headphones, and have listened for a couple of hours.
So far, the headphone output is pretty good, and non fatiguing.
I have not tried it for loopback testing so far.
Richard, is there any chance you could run some tests over your SRC2496, and let us all know what you find.
Thanks, Dan.
I have not opened the box. If I read the manual, and it is something I can do without a steep learning curve to operate properly.... etc. then yes. Pls keep playing with it and see if there is anything I should look out for or focus upon.
-RM
What is conspiciously absent on the specs (unless I missed it) is CMRR over frequency. This is what separates the men from the boys in diff probe land.
The 70dB CMRR at 60 Hz is easy. I want to know what it is at 1kHz, 10kHz?
Jan
Jan
It's apparently intended only for power line measuring, so I would assume that the CMRR is much worse at higher frequencies.
CineMag makes an input transformer that has really good CMRR:
http://cinemag.biz/line_input/PDF/CMOL-2x600T2.pdf
Thx--- I'm ordering one.
-RM
Unfortunately only sell to the United States. 🙁
Matt at QA400-land said he shipped one out to me. I can measure the CMR at other freqs...
THx-RNMarsh
THx-RNMarsh
Jan
Measured CMR at 10v rms input level:
X10 range -
100Hz = -72dB
1KHz = -72
5KHz = -65
10KHz = -63
100KHz = -61
X100 range -
100Hz = -75dB
1KHz = -75
5KHz = -74
10KHz = -72
100KHz = -70
I'll look for a trim inside (or an R that can be trimmed)
THx-RNMarsh
There are three multi-turn trim pots nside.
One of the IC is the SSM2143.
So, there is some potential for better CMR numbers thru trimming R's.
THx-RNMarsh
THx-RNMarsh
One thing to look for is CMRR from a non-symmetrical source, one where the impedances are different. E.G. tie and external source to one input and connect to the other with a 1K resistor.
Second would be to see how low the distortion is in all the permutations of drive.
X10 range -
100Hz = -72dB
1KHz = -72
5KHz = -65
10KHz = -63
100KHz = -61
X100 range -
100Hz = -75dB
1KHz = -75
5KHz = -74
10KHz = -72
100KHz = -70
THx-RNMarsh
Thanks Richard - that's very good, I want to get one! At that price!
They should advertise that!
Jan
One little thing I do at home is adjust CMRR with the system all plugged together... cables and all from preamp to amp input. I keep talking about the System... this is one way to dial it all in together (for CMRR).
This way is a lot better than just adjusting the amp alone. It takes in the Zo of the actual preamp being used and any unbalances in distributed interfacing elements.
THx-RNMarsh
Just found out that the FFT size can be changed in the Default.Settings file by altering this line:
<BufferSize>4096</BufferSize>
How come the THD at -10dbV is significantly higher at 192Ksps? With my QA400 it is 0.0018% vs. 0.00073%.
how many averages?
perhaps the added bandwidth is adding noise?
nothing else in the setup has changed?
etc.
also it may just be an artifact...?
etc.
<Averaging>0</Averaging>
Where can I set averaging in the software?
Measured value was THD, not THD+N. Also when you check the many QA400 screenshots posted in this thread, THD is clearly higher in 192Ksps mode.
Can someone confirm this: If the "round to eliminate leakage" option is checked in the generator, the test frequency will be an exact multiple of the frequency resolution (sample rate divided by FFT size). In this case no windowing is necessary ("Rect" window function) because each harmonic will fall exactly into the FFT's "frequency bins".
The windowing is still necessary. The benefit of setting the test in the center of the bin is better amplitude accuracy. It really easy to see the effects with the QA400. They show immediately.
The distortion is higher at the higher sample rate. Two issues, first, its just higher. Second, at 192 there may be more harmonics for it to add in.
- Design & Build
- Equipment & Tools
- QuantAsylum QA400 and QA401
