Improving the LM3886 amplifier
Hello,
Currently listening with LM3886 amplifier 20,000μF for each side in the psu.
The sound is very detailed, and have dark sound signature.
But the highs is not pleasant and the mids is laid back.
In summary the sound not "live" as the great LM1875.
Are there any recommendations how to improve the LM3886?
Schematic of amplifier:
Hello,
But the highs is not pleasant...
I've said it before and I'll say it again, this amplifier needs to have feedback compensation. Try a 27pf capacitor in parallel with R10 and see if there's an improvement.
Also, not helping things is that this layout is terrible, rip out the two small decoupling caps and place them right on the chips pins. 100nF X7R caps are perfect for this job.
I hope this helps.
How does the power supply look? Schematic please
A couple years ago Bob Cordell showed the New Jersey Audio Society how to build a chip-amp based upon the LM3886 -- we had it in comparison to a Pass Aleph (not a DIY Aleph) and hotted up Thors.
The secret is no secret -- it's in his book -- you want to drive the inverting input of the LM3886, not the non-inverting input.
Cuts and straps to implement star grounding (of a sort)
The cuts to make in the copper I've shown in magenta. Wires to add are shown in black. You'll still have a loop (because the signal cable running left-right has its shield in parallel with a PCB track) but I'm hoping there's no nearby field....😛
WARNING!!!
Remove 220 VDC connection from PCB.
Replace Ci for one in the range of 47 - 100 uF.
Move Cin to parallel with R2.
Looks like the input signal is filtered by parts of the pre amp. You need to redesign (rebuild) the input section of the amp. Missing input cap in schematics (2-4uf).
