EMU 1212M for measurements
Joined 2004
I just got an EMU 1212M for measurement purposes because it uses the AK5394A ADC. Here are some essential as received measurements.
They are all made in balanced mode at +4 level setting.
The performance is quite good but not as good as I get from the demo board.
The Third harmonic is exceptionally high. That is also high on the DAC as well. My guess is the odd JRC2058 opamps. They look like they are from an earlier technology node (to use the IC industry jargon).
Next step (after CES) will be to replace the JRC opamps with LME49720's to match what I'm using on the demo board. I'll document the process.
The drivers seem problematic. The Win XP system was really stable before I installed the card and has been locking up intermittently ever since. For my purposes the DSP manager interface is also very much in the way. Learning curve ahead.
I think the drivers are going to drive you nuts. I had to put the 1212 that Dick sent me away. I just couldn't take anymore. It's designed for musical recording and is very protected. Couldn't even change sample rate settings from within ARTA or any other software.
Are you using the ASIO drivers for this?
Disabled Account
Joined 2012
I think the drivers are going to drive you nuts. I had to put the 1212 that Dick sent me away. I just couldn't it take anymore. It's designed for musical recording and is very protected. Couldn't even change sample rate settings from within ARTA or any other software.
Now you know why you got the 1212. :) Happy to know it isn't just Me.
I have developed a zero tolerance for stuff like this.
P-n-P and auto-config etc is the name of the game for me. That is what appealed to me about the QA400. BUt, it too was about to be thrown in the garbage can because it didn't work correctly --- until the people who make it responded and quickly fixed the software and now it is P-n-P for me without negative operational issues. Now, if they would just make one with a better ADC.
-RM
Wimp!
I refuse to be defeated by simple computer stuff. Although the fixes may be worse than the problem. Its not my main computer at all so I won't be too concerned if it crashes every few days. However if Linux support is good I may switch.
He's right though. Things should just work.
I didn't have any crashes running under XP. It was all the blocking that bothered me and the noise performance poor. Never seen so much grass. Too bad because it such a nice ADC.
Joined 2004
ASIOforall is a hack to bridge from windows to ASIO. What is needed is better hardware drivers and those would be very hardware specific. The problem is the DSP stuff on the card. Even if its completely disabled it needs to be loaded or the card won't work.
I will be trying it on a clean installation with a fast simplified system to see if it can be stable.
I am getting very good results. Swapping the opamps may get the 3rd harmonic down a bunch. The LME49720's are cheap and worth a try.
diyAudio Chief Moderator
Joined 2002
Asio4all works for my EMU Tracker Pre, but loses performance vs. WDM. Pictures are on XP. Alas, Win7 is a problem for any original Tracker's drivers.
So A4all comes to the rescue. Can you explain why it loses SNR performance on A4ALL by not supporting 48k? Skips some hardware bits maybe? Any better settings to propose on A4all for SNR?
I like the Tracker bcs very portable and I can use it with any measurement software. I think I can't do that with a QA400 which I would get for backup or just to have it installed ready for use on the bench when the EMU could be in the tools case. But it only runs on custom SW, right?
Disabled Account
Joined 2012
Wimp!
Yes, I will admit it. I have wimped out. I spent years screwing around with computer hardware/software/interfaces for work projects and experiments. My frustration level and tolerance for software issues is now very, very small.
But, happy :) that you want to do it. I'll just do what ever is found to work best and use that. [I still have a emu 0404 in the closet. Any hope of that being useable?]
Thx-RNMarsh
Joined 2004
The noise may be some resampling in the background. I have a Tracker pre and a 0404. I have been able to make some complex acoustical measurements with them. Its the usual 1 day of prep and debug and 30 seconds for the measurement (ground plane frequency response of a speaker).
The QA400 is designed around a special USB protocol. Its Matt's way of working around the USB audio limitations on Windows. Either 96K and not necessarly full duplex or 192K and licensing/building a Windows driver to support. Essentially he uses bulk transfer and retries when it gets hammered which is why it doesn't work with normal stuff. Its also why you may see the error flash, that might indicate USB bus contention. What is needed for the QA400 is more test functions. We need to lure a programmer into building some more enhanced test scripts for it. There are examples and it would not be difficult to list the most useful scripts for various electronic measurements. Its not for acoustic measurements. My interface project is to make it more useful for electronic measurements.
I have a 1212M and an 1820M, they both work OK under Windows 7 and Windows 8 actually. I used to have some occasional weirdness in Windows 7 but it's gone in Windows 8.
The automatic sample rate switching between 44.1 and 48 does not work in Windows 8 though, it did work in Windows 7. You always had to manually load a session for 96 or 192k.
I would not use XP if someone paid me.
mkc
Joined 2002
We need to lure a programmer into building some more enhanced test scripts for it. There are examples and it would not be difficult to list the most useful scripts.
Hi Demian,
Since I have a QA400. What scripts would you like?
Btw. Tracked down a very cheap 1212m, which I might as well grap. If not anything else, I can perhaps tab onto the lines and connect my USB interface to the ADC.
Best regards,
Mogens
Disabled Account
Joined 2012
How accurate is the data near and below -100dB?? Same question to Salas, Chris.... and others with sound cards et al.
Here is ref. AP-2722
Thx-RNMarsh
