F5 Turbo Builders Thread
Folks:
I'm building my first F5T amp and would like to confirm the grounding scheme before doing something particularly dumb. Can someone confirm that this diagram is correct?
Many thanks,
Scott
For a very good discussion of this subject that contains excellent and practical advice, refer to Rod Elliot's page here:
Power Supply Wiring Guidelines
roger57:
Thank you. Rod Elliot's pages often provide very helpful information (and a little attitude) for this newbie, but not in this instance. I'm using power supply pcbs for my F5T project and have wired the power supply correctly, as confirmed by my dim bulb tester. My question wasn't about the power supply, per se, but about grounding in accordance with Nelson Pass' F5T article. It appears to me that Nelson's grounding scheme can be built very simply (and almost entirely) on the bridge rectifier that is part of the ground. I simply want to verify that what I've drawn matches Nelson's design.
Scott
roger57:
Scott
Your drawing is okay. It reproduce the grounding scheme of the PSU diagram.
Well, I really don't know anything about the coils you are using - they might be every bit as good as the Hammond choke. I had mentioned it just as a suggestion for anyone who might be considering a similar CLC type filter arrangement.
You mentioned they were about 2mH - this is at 60Hz? What's the DC resistance?
The DC resistance is 0.297 ohm. Erse Audio don't give a graph about the value of their coils vs frequency but being audio coils, the value should be stable from 20 to 20000 Hz, no?
antek vs. avel lindberg vs. other toroid manufacturers in USA
I am building an F5Turbo V3 utilizing two 800va transformers with 34/35V secondaries and am considering the Antek and the AvelLindberg toroids.
Any opinions on quality or other issues from these manufacturers or others? Are these on par with say Plitron?
Thanks. Nash
Has anyone out there successfully built a balanced F5T yet? Looking at the balanced schematic in Nelsons F5T article, it seems like building a balanced F5T V2 is pretty feasible using the store boards. Just wondering if anyone has given it a shot yet.
Folks:
I've hit a snag in the first channel of my F5T V3 build. I'm using diyaudio's F5T boards (version 2). My wiring diagram is attached. I'm reading about +/-48 VDC off the power supply, output boards and gain stage board. VDC readings across TP2 and TP3 on both the P and N sides are 0.00, regardless of my adjusting P1 or P2. I'm also getting 0.00 (or 0.01) at the output.
Can someone point this knucklehead in a useful direction?
Thank you,
Scott
