Now, WHY would we want an 'improved' power supply buffer. The most important reason would be when we want the very HIGHEST output swing from the amplifier for the existing output transistors used. Even if we use the 'best' output transistors, we run into 'safe area' problems and potential overheating.
With the existing design, we can just increase the raw power supply voltage, but this will not give us maximum output from the amp, only.
To get a slightly higher voltage swing, we have to do what JBL taught us, almost 50 years ago, we create a separate driver supply voltage, usually practical when we custom build the power transformers for each amp type, but sort of a hassle for DIY'ers.
This way we can create a DRIVE VOLTAGE to the output stage equal or even greater than the output stage can reproduce. This gives us optimum power output. Other 'advantages' can be added as well. (more later)
Might be interesting, at the moment, to show VAS maximum voltage swing and maximum output voltage swing of the power amplifier loaded by 8 ohm. Both as clipping. And maximum swing for undistorted output (180W/8 ohm approx.).
If we wanted to show a complete schematic, then the Parasound A21 or even the 20 year old Parasound HCA1200 would be even more complete, but intimidating to most of the usual participants of this website.
We're staring at the ground and drooling.
Pavel, it might be interesting to show recovery from overload and what happens on the edges of reactive loading.
Some readers apparently need more schematic to keep them occupied.
Here are 2 examples of Parasound designs that are still available on the used marketplace: I use the 1000 myself. I have used the 1200 as well. They are both 'pretty good' amps, but we can do better.
  • 1000.pdf
  • HCA1200 mk2.pdf
It was output clipping without any doubts.
That part was clear. The question is what happens immediately after? The clipped waveforms into resistive loads look clean, no indication of squegging or sticking, but tonebursts into reactive loads tell the tale. That's one reason that PowerCube (or similar) measurements are very useful for judging commercial amps and diy amps meant for a wide range of speaker types.
