if You have 90v and 90v thats 180v 50hz lets say 1 amp
if You have 90v 100hz You will have 2 amps of power because its double the frequency
You will have the same power as 180v on 50hz
DOnt worry Audiosan I am way more into electronics than this amplifier thing
That calculation is wrong then they calculate wrongREAD! i'm not going to sit here and argue.
You have double the frequency and double the power
so you must multiply by 2 end of story
jizes. you know what? just live in this little world of Your own calculations and dream away. one day reality will hit you and you will be very disappointed.
Im not dissapointed and I know what Im saying like I said Im way more into electronics that You think
Doubling the frequency doubles the power
If You think Your calculation is right go for it I dont want to argue because I know what is doubling the frequency and power
well well. i guess my 25W F5 amp acctualy is a 140W amp then. funny thing.
Chill out my friend 😀
and read about frequecy doubling
forget on that calculation because its wrong formula
Its correct only if You multiply by 2 because You double the frequency and double the power
Ok I dont want to argue about nothing Im just saying that something is wrong in Your calculation
Subject your +/-80v amp in oscilloscope test and get the clip voltage and see if you can have a 798wRMS...😛
Netkis, it is an ac signal that moves plus and minus 90 volts from ground, think of a sinewave. At any point in time it can only be at plus or minus 90 volts, from that point you can calculate the power dissipated. I hope my explanation is clear.
Hi Netiks,
Power is described here: AC power - Wikipedia, the free encyclopedia
How will power increase when voltage is doubled?
LC , Ricdelros, you shouldn't stop their discussion.🙂
Haha! Diy community is reading the thread, a Wrong Impression in audio mathematical expressions can spread like a virus, so it should be controlled.😀
Then Why they use 1200watt +/-90v transformer to get only 350watts rms at 8 ohm and they say its 800w rms amplifier output and use 3000watts of transistor power? For only 350w rms at 8 ohm? strange
Why didnt they make amplifier to work at +/- 160 volts and say thats 800w rms
I didnt see amplifier design in my life that says power amplifier 8ohm 800w rms use +/-160volts
- eBay Amp 650W AB Class - Someone Try It ?
