CFA Topology Audio Amplifiers
Thanks ...
Thank you , Apex and Joni.
Those examples of Wilson mirror based amps sure helped. Further refinement
to my amp .... I'm now into the "golden realm" of ppm. 🙂
I even retained the "heart" of lazy cat's input stage. I was going to cascode
the VAS , but I already was at (rail - 7V) due to my wilson /triple EF.
Apex's marantz (what model ?) uses the wilson as a "current multiplier"
instead of a typical mirror. Full power THD dropped from .002% to .0007% ,
nearly the same as the current ratio.
By RNmarsh - OK. Seems many companies - not just small 'audiophile' types have gone away from strictly VFA/differential input/VAS/OPS - the blameless configuration - and its been that way for years now. But, I think some of the designs seen here and elsewhere with great semiconductors; fets and MOSFETs, better passive parts et al are up to the task with benefit of advanced SIM PC/sw.
Yeah , 🤐 garbage ! "walmart" Class D / various IC driven darlingtons ...
and of course , just barely enough power supply to avoid embarrassment.
I like older vintage Japanese amps , some over 20 years old. Recap them
with double the uF , they outperform modern offerings.
They are mostly VFA/EF3 with sanken OP's - I just sell the new stuff to
the "sheeple". 😀
Our DIYA creations outshine even the best OEM's , I've yet to see a
manufactured amp under 3K$ with 2- 600VA toriods + 80Kuf (PS).
OS
OS
Here's the frontend/housekeeping I am currently working with It Has now been playing for more than 2 years. I have tried it with several different OPS. from laterals to triples.
While we wait on discussing compensation and how easy it is AND have low distortion with CFA --- here is something that will make everyone happy ---> VFA and CFA designers - Something in this one for everybody:
Who would like to SIM this more recent topology into an audio amplifier design?
Thx-RNMarsh
The second one looks like the H bridge CFA config. Great because you get hi-z inputs on both + and - Inputs. I simmed this a few months ago. Very low distortion and extremely high SR. Looks similar to the structure discussed in the ADI app note that I based my sims on.
Thx-RNMarsh
Buf634 is, dual bias mode, protections, and bandwidth adjustment. I am using it at my last schematic.
laterals are softer than the BJT's, some would say more airy and delicate, but also to a degree somewhat restrained and less expansive in the dynamics than the BJT's.
I fail to hear much difference between dual and triple EF. (but this may also be a little cluttered as there also was some alteration to the PS)
I would like to work a little on the OPS that RNMarsh showed An interesting Diamond.
Just saw this.
I/V stage with current feedback amplifier CFB op-amps
Transimpedance or current feedback amplifiers are still relatively new to audio applications, since they are primarily designed for video circuits. While the AD846(an early high-performance example) was successfully used in TAA, transimpedance amps may not be completely familiar devices(the AD846 datasheet contains a detailed discussion of transimpedance amplifier theory). Interestingly, they posses several performance attributes quite useful in audio circuits. Among their virtues are very high slew rate and bandwidth, high output current, and the ability to drive low impedance loads with excellent linearity. Because of these factors, more designers and audiophiles will use them.
High Performance Audio Stages Using Transimpedance Amplifiers by W. Jung – >>>[ LINK ] (Missing)
I/V stage with current feedback amplifier CFB op-amps | DIY AUDIO BLOG, AUDIO WORKSHOP
The AD846 is now obsolete, but shows what can be accomplished in audio using knowledge gained from utilising Video techniques 🙂 I'm only posting this as a talking point, & for futher insights etc.
I believe that it's due to the different tempo of the device families, Bjt's are expansive in nature where the others are the opposite. I am not sure if those assumptions has any merit.
One thing I am very very sure of is that the most important may not be the circuit, sure the circuit holds the ultimate potential, but the execution of the amplifier, PCB Grounding, PSU, cabling, is of equal if not larger importance. The Box and the mechanics of the box also plays a huge role. I have made an amplifier in a super expensive milled solid enclosure, just only to find it simply sounded terrible, compared to the same sample playing on a wooden plate. Aluminum/hysteresis and output currents somehow does not match.🙁
This new-ish topology is from Burr-Brown OPA660 App Note, BTW.
Thx-RNMarsh
it is 2 decades later
811 is a really poor sub for 846 - the 846 specs were unique, tried to establish a new "precision" CFA category - guess not enough demand
846 has 50-100x the gain of the other 2 mentioned, 1/10 the Vos of the 811
and few here seem to give the high current noise spec of the -inputs of these CFA the deserved attention
you can get better performance in other CFA op amps now, but without the Tz/compensation/hi Z output pin - which the 811 never had
the only excuse I see for 811 is today is if you are a slavish follower of Gurus and rumors and can't read datasheets - I doubt Walt Jung would choose it today for new design
I agree -- the pos vs neg tempco of the OPS power devices affect device parameters when under high current operation -- expan - pos and compressive - neg tempco. A subject to study in more detail.
And, yes, layout, especially for fast amps/wide BW amps.... layout is critical to match the SIM and work as predicted. But those are for other forums.
Thx-RNMarsh
It would be good to add vertical MOSFETs to the discussion. Have found that with the same front end that the character of the amp changed with the output devices. The verticals somehow sounded brighter when compared to Laterals. (Don't like making subjective comments). Not tried BJTs yet with said front end.
Edit: Have to wait till the next prototype is functional. The one above met a quick end due to violent oscillation and no gate protection on the MOSFETs. Won't take that short cut again.
I have never used vertical fets for OPS, I don't find them close enough in N&P channel matching, and then it also bugs me that the larger die has huge capacitance. But that's maybe just my excuse not to open another chapter. I find enough challenge in the devices I try to thame/master.
I have never used vertical fets for OPS, I don't find them close enough in N&P channel matching, and then it also bugs med that the larger die has huge capacitance. But that's maybe just my excuse not to open another chapter. I find enough challenge in the devices I try to thame/master.
I know what you mean about N and P channel mismatch. That's why I decided to go with error correction on the OPS. The main benefit to verticals was that they are relatively cheap. This was a big positive for me having spent loads on my first amp design only to end in failure.
Don't think the higher input capacitance is a major issue as long as the drivers are up to the job.
I think my struggle with MOSFETs is part of the reason I haven't got round to BJTs yet. Not enough time. Wish I could spend all day every day on this stuff. 🙂
I believe, yes, dynamic tempo of devices are very important on the listening result. One more reason why we whould like to get other measurement methods than continuous signals.
About CFOPAs, i regret my favorite for audio: OP260. Very transparent, and using a higher feedback impedance (ok for most of audio circuits) than their equivalent devices designed for low z video. It is at work everywhere in my hifi system, and i used thousand of them in mixing desks.
This here with the dynamic tempco of the the devices is a little bit in the direction of memory distortion. I have a sense it's really important, but not really sure how to quantify it. The same goes for GND impedances. I have noticed a great improvement in dynamics and resolution when GND connections are really good. but it's not something I can see in my measurements. These issues are really important for the amplifiers ability to convey the emotions of the music.
