DIY Good Class D amplifier
SG cant drive GDT,because it have pwm od another type than ouput pwm.See schematic.Simulate if don't know.I tried GDT yelow toroid from PC and it's good when add totem pole after two diodes and 470R.Yes,SMPS is usable,TDA only revised my PCB.SMPS is my 😉
I don't have any test equipment here so it's only idea,not tested.You should test it.When I buy scope,I will try with GDT,I like this.Darlington is used because of base-emmiter voltage and classic BJT with diode shouldn't work.
Any sugestions will be good.
There's schematic:
