1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer + chassis
3. smokingdog: DAC module + output stage
4. gde3: DAC module + amanero + transformer
5. villanueva: DAC module + amanero + output stage + transformer (item6)
6. CAAD: output stage only
7. Blackberry: output stage only
8. Mas Penk: DAC module + amanero + transformer + chassis
9. rade95: output stage + chassis
10. vmoreau: DAC Module
11. sandor: Complete DAC without output stage (option 6 without option 2)
12. Erlend Sæterdal: Output stage only
13. claudio52: Output stage only
14. Nick F: Complete DAC exclude output stage (item 6 - item 2)
15. xtomm: output stage only
16. brgds: DAC + output stage + amanero
17. danny_66: output stage only
18. anjogi: amanero + DAC + output stage + transformer
19. Jazzbear: DAC module + output stage + transformer
20. frankwilker: DAC module + Amanero module + output stage
21. NKL: DAC module + Amanero module+output stage+transformer
22. PeterKD: complete DAC (item 6)
23. rredline: Output stage only
24. schallundrauch: complete DAC (item 6)
25. Stenachio: Complete DAC without output stage (option 6 without option 2)
26. ervstil: DAC module + Amanero
27. linuxfan: output stage only
28. msaywitz: AC module + amanero + output stage + transformer + chassis
29. rowli: DAC module + amanero + transformer
28. msaywitz: DAC module + amanero + output stage + transformer + chassis
30. Claudio M. DAC module + amanero + output stage + LL1684 pcb + transformer
31. gjorgji: output stage only
List of 30 members. I do not get more!
Thank you all!
This GB appears to be capped at 30. I'm unsure if this applies only to the DAC portion or all components.
32. ceausuc: Amanero
No, it would not hurt the dac. The dac chip has built in series resistors that should keep it safe from shorts. Be aware that there will be 1.65V offset that needs to be handled. There will also be some out of band noise. If your amplifier has very high bandwidth and/or marginal stability this has to be managed as well.
There are some good reading in this blog entry: How Good is ES9018 in Voltage Mode? (Part II) | H i F i D U I N O
There are also some entries in "DAC-END R (ES9018) full assembled board"
Best Regards Christian
Would be possible to use the dac without the output stage? Besides the fact that the gain is very low... could be damaged in any way?
I did but it is much better with transformers.
3d image of a dac with LL1684,
The PCB V2 dac will be gold plated!
you see! thank you
you see! thank you
3d image of a dac with DCD out put,
you see! thank you
you see! thank you
Below is the list you have registered and sorted by my group. Please check if there are errors or changes please help me complete:
1/Choice 1: full
1.adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
3. villanueva: DAC module + amanero + output stage + transformer (item6)
4. PeterKD: complete DAC (item 6)
5. schallundrauch: complete DAC (item 6)
6. msaywitz: DAC module + amanero + output stage + transformer + chassis
2/Choice 2: output stage only
1. CAAD: output stage only
2. Blackberry: output stage only
4. Erlend Sæterdal: Output stage only
6. rredline: Output stage only
8. linuxfan: output stage only
9. gjorgji: output stage only
3/ Choice 3: DAC complete without output stage
2. Stenachio: Complete DAC without output stage
3. Nick F: Complete DAC exclude output stage
4. Mas Penk: DAC module + amanero + transformer + chassis
4/ Choice 4:
1. smokingdog: DAC module + output stage
2. gde3: DAC module + amanero + transformer
3. rade95: output stage + chassis
4. vmoreau: DAC Module
5. brgds: DAC + output stage + amanero
6. anjogi: amanero + DAC + output stage + transformer
7. Jazzbear: DAC module + output stage + transformer
8. frankwilker: DAC module + Amanero module + output stage
9. NKL: DAC module + Amanero module+output stage+transformer
10. ervstil: DAC module + Amanero
11. rowli: DAC module + amanero + transformer
12. Claudio M. DAC module + amanero + output stage + LL1684 pcb + transformer
13. ceausuc: Amanero
Thank you!
1/Choice 1: full
4/ Choice 4:
Thank you!
Quanghao,
I would like to add the assembly to my order. It should now read:
6. msaywitz: DAC module + amanero + output stage + transformer + chassis (Complete set: Item 6).
Do you want us to make the changes as before by copying and pasting the complete list (as modified) into successive posts?
Hello Quanghao,
Question:
when i selected the "transformer" option. This means hopefully all 3 transformers?
Have i to state the accesories like on-off-pcb, mains plug extra, does this belong to the complete kit only?
I would have these accesories also, all except case.
thank you very much.
jogi
Question:
jogi
Quanghao,
DAC Module 1 will be added to the power switch PCB
no electrical plugs, Above are pictures demo
Quanghao,
I rearranged so that you are easily distinguishable part of their choice! And also let me know of your choice!
thank you!
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board - version 2
