More spy info see picture from "First One" prestage. If it's SMD-film, SMD-ceramic or changed since don't now (Link: http://www.diyaudio.com/forums/solid-state/239708-vssa-50-a-5.html#post3598917).
😀 Replaced with Vishay film cap, just as in VSSA. All parts individualy tested for new First One amp, priority is of course sound quality. Right now first new First One PCB is in assembly process. 😎
Played with simulation of GB circuit (copyrighted so please don't ask schematic other than Andrej). Implemented Esperado schematic from post #2629 the best my hobbist skills allow, remember it's simulation only. The audio band group delay gets perfect linear when zoomed into nano seconds. Christope i am in doubt about truth for 20Hz square, could result be right ?
Yes OK, that was also the case in SSA amp without FB caps. Now please simulate thermal behaviour in VSSA especially input stage, if caps are removed. 🙄
Well. If there is, as i fear, too much rock'n roll for the Andrej Sisters ( Andrews Sisters' "Boogie Woogie Bugle Boy of Company B". [VIDEO]), we could think about some servo ?Yes OK, that was also the case in SSA amp without FB caps. Now please simulate thermal behaviour in VSSA especially input stage, if caps are removed. 🙄
Let list some advantages:
1- It is less expensive than big lytics and lot smaller.
2- As we don't have residual signal at HF, we should use some high value ceramic SMD caps for the FC without resonance's fears.
3- The FC can be very low, with little impact on HF distortion and group delay for (BYRTT ;-), and huge improvement on BF distortion.
4- No need for offset adjustment's networks and their multi turns.
The cons are:
1- (little) added noise.
2- Complexity (specially rails reducing voltages circuitry).
3- The price of a nice bottle to Richard Marsh ?
🙄 Yes Andrej i am a SPEC dreamer without skills to see drawbacks 🙂.
But another thing about feedback cap influence. Is it possible to make group delay opposit in lows without ruin FR as a curve for repairing speaker driver+cabinet highpass function, as been possible nowadays in digital domain by FIR filters. I ask this because that cap position control AC swing by amp, and maybe a clever circuit could make that function.
What about 2m2F//10uF SMD//small film caps, like 0n3F to 1uF?
Where do you guys source your Vishay's? 😡
Will try to post pictures of my humble effort for the true VSSA soon.
M.
Check for 181216021233 on eBay.
Cheers!
A try, the first i bought myself (WIMA) and fits 100% and at same it's Mouser Chile link, last four links to Farnell (Element14) Denmark then change countrysite and see if it works, good surfing...........Where do you guys source your Vishay's? 😡..........
Thank you guys. You are true gems.
Unfortunatelly, dear UMUT is not shipping to my country...
I will study the other options (though Farnell has prohibitive shipping costs)
Thanks again.
M.
Thanks again.
M.
Thanks again.
M.
Hello Max,
I bought them here:
5x MKT Kondensator radial 10uF 63VDC RM15 ; RoHS ; MKT1820610065 | eBay
Marko
Hi guys, I forgot to fit the spacers before installing the VAS transistors and had to cut them out to des older without ruining the boards. Does anyone know where I can find replacements?
Hello Max,
I bought them here:
Marko
Thank you Marko.
This is optimal and I bought at once a good reserve. 😀
Gratefuly yours,
M.
Fairchild's KSA/KSC are stocked by Mouser. 😉
Please follow Installation manual step by step. 😉
I see a good probability to destroy the sound chasing after a non-existent problem. Good luck.
Yes LC but already E range for 1381 and D range for 3503🙁🙁🙁
Marc
Thank you Marko.
Gratefuly yours,
M.
No problem Max,
I am glad to help, he has suitable electrolytic caps for VSSA as well if you not tied to Nichicon FG.
Marko
No worries, no DC servo in First One. If FB caps would be removed there would be no output DC offset problem at all, only input/VAS bias changes in symetrical manner.
DC servo is out of question here. 😉
Sorry, but, unless you introduce some kind of compensation, more you have gain, more you have offset problems.I see a good probability to destroy the sound chasing after a non-existent problem. Good luck.
AS used by L.C., the caps are here to reduce the gain of the input stage at DC,
The problem is they *pass* the signal in the audio band, at relatively low impedance, so, need to be high µF.
If you design accurately a servo, it will not introduce distortion in the audio band, as it will produce no signal except at very low frequencies.
A servo *add* feedback at very low frequencies. The L.C. cap reduce the gain of the input stage.
As the IC used for servoing can be very high input impedance, we can use low values caps, film ones, that's the advantage.
Hi send a PM to PMI and tell you have LC's GB PCB's and the situation, then i think his good heart will help you.Yes LC but already E range for 1381 and D range for 3503🙁🙁🙁
Marc
Link PMI profile: diyAudio - View Profile: PMI
Link PMI throug hole VSSA: http://www.diyaudio.com/forums/soli...hrough-hole-pcb-build-thread.html#post3682318
It seems to me that we have 6-7 who wish to 'improve' the standard build/circuit. How many are satisfied with the original as built to the original guide?
I believe everybody, and, as-it, surely one of the best sounding amp we can find.It seems to me that we have 6-7 who wish to 'improve' the standard build/circuit. How many are satisfied with the original as built to the original guide?
Pure reptilian reflex to try to do always better 🙂
- Vendor's Bazaar
- VSSA Lateral MosFet Amplifier
