And here's me thinking it was deliberate! That's why I posted the crytic comment earlier on - thought Mooly was trying one on ... 🙂
Picked it up when looking at the overall waveforms in Audacity ...
As if 😀
From your tone I take it that you have taken measures in ensuring the latest offering (TLE2072 with SR of 45V/us) is stable in the circuit.
So, when there is no design "mistake", I believe I could prefer the TLE (even tho I have never heard it). It may stand out in sonic, or it may stand out in distortion (like most non musical expensive opamps).
It is not easy to stand out in both sonic and distortion, so I believe TLE will stand out in distortion. WAIT! There is one file is very close to the "original". The location of the file is not far from Peach and as of now it gets zero or one vote 🙂 I will check this file at home tonight.
The TLE2072 is quoted as being an updated and "new improved" TL072. It never seemed to become favourite in the way the original TLO's did at the time.
No, it was noticed - but most of us didn't realize what it was. Which is kinda lame, I admit. But we thank you for pointing it out to us. 😉
Yes, there were a few comments I recall reading about it being "phasey" or something. I should have had a close listen at that stage suspecting a problem but.......... 😀
I'm thinking if the the 741 is too slow that the "sharpness" in the signal gets rounded off by the slower amp. Negative feedback could cause cause overshoot in the slower chip and give an impression of sharpness too so, heck, I could be wrong on my pick.
IMO, slow amp should be aggressive at trebles such as violin. I'm glad to know that something is wrong with previous orange because orange cannot be 741. I guess orange is one of the fastest. I will find out today.
Now pomegranate is aggressive. It could be because of low slew rate. But 4558 is also slow but i believe the 4558 is a new production, not vintage (even CA4558 cannot be as good as CA741 i believe). Generic 741 will not sound like pomegranate either.
If Mooly could reveal the "wild card" I would try to find out which opamp is which file based on their parameter and perceived sound quality.
Mooly, please don't publish the results on this thread but refer those who want the answer to another linked thread. I don't want to accidentally read the results in this thread.
I'll have to try & download the files but it will take me a long time with slow internet
I was a Blind Listening Test guru for a large part of my previous life and would like to make some comments.
Anyone recommend software to switch between 3 (or more) stereo files running simultaneously?
- for something like this, levels MUST be matched to 0.1dB or better
- 10 is far too large a number of choices. I always did ABC tests. For something like this, 2 out of the 3 presentations might be identical
- You need to weed out the deaf Golden Pinnae. An easy way to do this is to have 2 presentations of each item. Anyone who gives Chalk & then Cheese to the same item (disguised) gets his results binned. Definitely have this with the Original.
- You ONLY ask preference of those who give similar (very rarely identical) rankings to the same item in its two different disguises.
- Someone posted a link to an ABC test but I'm not sure its the same as what I used to do
- Some of my Blind Listening Test Panel were remarkably perceptive. But most (all?) audio reviewers do much worse than the Man in the street .. especially those who claim they are Golden Pinnae. There are very few exceptions that prove this rule.
- Even the best true golden pinnae are opinionated & biased. There are people who's ears I trust very much in Blind Listening Tests and much less in a sighted test. I'm one of them. 🙂
- The Woman in the street is usually better than the Man in the Street
- The true golden pinnae ALWAYS say something like ".. I think they all sound very similar but ... "
- Chalk & Cheese comments are a sure sign of deaf Golden Pinnae 😀
- There is music that is better for tests of this sort. Also test signals .. but you NEVER listen to test signals until you have your full set of results for music. Also ways of recording music so its more useful for these tests.
Those of you who have done the test, please don't reveal anything on this thread. Do it in the results thread. I think its valid to post things that you notice, eg the violin sounded slightly edgy at 3:32 but not identify which presentation you noticed it on.
When you do Blind Listening Tests for nearly 2 decades, you find Peer Pressure (among other stuff) is a HUGE influence.
I'll let it run a wee while longer yet 🙂
Some interesting points and observations you make there. The "chalk and cheese" bit is interesting because I often see in other threads comments such as "the xyz" opamp just has no bass or no midrange and your left thinking "what 😱" what on earth are you hearing.
The 4558's are genuinely old having come from a 1983 ish vintage Sony C9 Betamax.
The wild card really is just that... I wanted to see if there was any statistical bias either for or against it.
And I can't wait to reveal all the results 😀 but in view of all the renewed interest overnight (after yesterdays pause) I think it only fair to let it run a little longer now. Some of you haven't had chance to download and compare them all yet.
OK. I'm officially on record. I cheated and looked at the files - because I can't really tell by listening. Mooly is making this pretty good. One of the files I thought was one thing has the channels reversed which completely changed my (lack of ) opinion. I THINK I know the unmodified file but after that ??? And I may be wrong there too.
G²
It's not good practice to visually determine the difference of audio files. Wave shapes can look very different but still sound exactly the same.
I have made some examples so people can experience this for themselves.
The sound files can be uploaded here: Zippyshare.com - waves.rar
Point of topic: Never use visual clues when you want audible clues.
The wildcard is also a 741??😀😀😀
Its much much much much wilder than that 😀
Indeed 🙂
Get the best headphones you can get and listen to a square vs sine wave. Once you get above a certain frequency (that is pretty low in the scheme of things) then sine vs square vs triangular all sound the same. Your age and hf hearing cut off point will determine what that frequency is.
If you sweep a square wave up in frequency, the harsh raspy tone gradually becomes smoother and smoother until you find that last trace of "audible harmonics" dissappear completely. Try it 🙂
Ok Cliff, I have not fully followed this thread, nor have I listened to the files....yet.But none of you GE guys heard it?
If that is not a "night & day" difference ....😉
I notice that no-one has mentioned (a few have hinted) the giant elephant in the room.
What do you mean by 'the elephant in the room " in this case.
Dan.
Another Blind Test For Distortion
I’m not well since Saturday evening so as expected I couldn’t do the blind test for musicality well on Wednesday (made mistake thinking that a file couldn’t be banana while in fact it was). But blind test for distortion is much easier so now I have a few results.
From listening all files I could hear one file stood out with the most distortion (Banana) and three files with the least distortion (Orange, Kiwi, Peach). So I selected 3 files for blind test (Banana as the worst, Orange as one of the best, and Pomegranate).
More than 5 blind test cycles were successful (100% accuracy) and was very easy. It was clear that the ranking based on the lowest distortion is: (1) Orange (2) Pomegranate (3) Banana.
Then I replaced Pomegranate with Pear and did around 8 cycles or more. On the first cycle I made mistake thinking that Pear was Banana but after hearing the Banana it was clear that Banana is worse so for another 4 cycles where I have to choose between Banana and Pear I made no mistake. Of course, when it was Orange I could easily know.
So it was clear that the ranking based on the lowest distortion is: (1) Orange (2) Pomegranate (3) Pear (4) Banana. (To be continued tonight)
My plan was to rank the files based on:
(1) DISTORTION of music#1. The lowest should be original, next best should be expensive opamp like TLE2072. The worst should be old opamp like 741, 4558 and 4560. Here there is issue with how the files are having different SPL etc.
(2) TREBLE/VIOLIN AGGRESSIVITY AT HIGH SPL. The aggressive ones will be linked to low slew rate opamps.
(3) DETAILS AT COMPLEX PASSAGE OF MUSIC#4. The blur ones will be associated with low slew rate and cheap opamps.
(4) BELIEVABLE SOUNDSTAGE of music#3 or music#4. I don’t know how to associate this to the opamps except that it will be favored by me.
(5) ACCURACY OF VIOLIN HARMONICS. In some files the violin doesn't sound like string instrument.
To guess which file is which opamp, it will be good if there is data about input noise, unity gain bandwidth and CMR/SVR. But I will start with slew rate:
TLE2072 (45V/us)
OPA134 (20V/us)
LM4562 (20V/us)
TL072 (13V/us)
NE5532 (9V/us)
4560 (4V/us)
4558 (1V/us)
741 (0.5V/us)
TLE2072 (45V/us)
OPA134 (20V/us)
LM4562 (20V/us)
TL072 (13V/us)
NE5532 (9V/us)
4560 (4V/us)
4558 (1V/us)
741 (0.5V/us)
A lot of interesting discussion. My process was as follows:
1. listen to the musical selections
2. pick a favorite
3. vote
4. keep my mouth shut
2. pick a favorite
3. vote
2. pick a favorite
3. vote
Hey that was the same process I used. I do believe step 4 was one of the most important steps to not poison the process.
Indeed!Hey that was the same process I used. I do believe step 4 was one of the most important steps to not poison the process.
Please don't post your own results. It invalidates the test for others. See my post #165
I was thinking of doing the big unveiling later today as interest seems to be waning now.
I think you'll find some surpises 😀
What process 😀
I have mentioned that whatever the poll result, it doesn't mean much. From validity point of view, this poll is less valid than any of the many blind tests I have participated in. For most of you taking part in this poll, it is just for fun, isn't it?
Well, I have different view, interest and intention than you do. That's why I posted my result. And only Mooly has the right to decide whose intention should be prioritized.
There has been many debate between subjectivists and objectivists regarding how ears can really hear differences. The conclusion so far is: the golden ears are only fooling themselves and the subjectivists are right with saying that every opamps sound the same (or similar claims).
This debate will continue until next decades because nobody have proof, especially the subjectivists.
That's why I want to try to pin point each file to each opamp so if it is successful it can be a proof that it is really possible to hear differences and hopefully those experts who has terrible ears will understand their limitation.
For me, it is clear that I can hear differences. Otherwise, how can I have such a high accuracy in the blind test? Well, some of you will think that I cheat or something, that's why I want to do it down to detail so no such excuse is possible.
Of course I can post later at the end of the day, but I'm not sure I will have time, so that's why I did it while I have time.
Let me tell you something. Up until this moment, the subjectivists are not joining the poll. And they consider those who join are audio fools. And I'm not happy with that. But that's alright because at least I didn't vote either 😀
I was thinking of doing the big unveiling later today as interest seems to be waning now. I think you'll find some surpises 😀
The orange not a discrete opamp?
To kill 2 birds with one stone - many would regard 128bps MP3 as the pits, badly mangled sound, easy to hear the 'damage done'. Therefore, it should be easy to see that damage - in something like Audacity - there must be visual clues ...
Okay, here is a snippet of some intense drumming, solo work with cymbals going flat out, one track is the original WAV, the other is a 128bps MP3 of the same - size of the whole WAV file is 1,015KB, the MP3 is 185KB - so "severe" loss of information in the latter.
So, which is which?
The bottom one of course....
By telling your own results, you invalidate the test for people who haven't yet done it. I was going to do the test but I've now read too many results for me to be completely unbiased .. so I shan't bother loading the huge wav files on my slow line.I have mentioned that whatever the poll result, it doesn't mean much. From validity point of view, this poll is less valid than any of the many blind tests I have participated in. .....
loadsa mostly valid stuf
ANY previous results that are traceable to specific presentations WILL skew the results for people who are yet to do the test.
In my DBLTs, the listeners are always tested separately and are not allowed to discuss it with each other until the final results are out.
And you NEVER tell the listener what he is supposed to be listening too so he doesn't try to guess what is what.
Mooly, would it be possible to do another test after you release the results of this one? You could just change the names and order. Can the poll be one where you only see the results after you've done it and can we post all results on another thread. Discussions on the original poll thread strictly limited to stuff that ISN'T specific to identifiable presentations.
This would get better valid data out of the test. Please feel free to slip in some repeat presentations to weed out the deaf Golden Pinnae 🙂
- General Interest
- Everything Else
- ULTIMATE OPAMP SHOOTOUT... Where you get to decide.
