FET-hex explendit amplifier
Idefixes
I think Your 3 pair board is better designed from thermal point of view, the temperature sensor is located between ops transistors. In my case the temperature of bias sensor is approx 5-6 celsius lower than ops transistors.
Ok. I have the ability to mount direct on a output device as i made on BG1-MJL or my Nbip (see attached picture)
Recommendations for audio amplifier
Hi guys!
I see you have developed a multivariate amplifier.
Which amp would suit me the output MOSFETs and the BJTs tansistors, as we have in the power supply Ucc = +/-(35 ....40)V, Po = 220VA and spekers with impendans 4R.
So give recommended some any of your Amplifier that provides a defined exactly bass!😉
This applies to you, Mr Borys and Mr Indefixes.
Thanks the recommendation.
Cheers!:cheers:
Marc those PC boards design and quality just awesome!🙂 especially known is all hand crafted😀😀
Congrat..
Today I made the layout for the LatFet version, I have some high power dual diy EXICON and Class D mosfets, I would like to test those to.
I do have a 39-0-39V 600VA transformer for that project.
If your Capmu. work with these topology well I will use that to get some voltage drop for the one pair LatFet.
To replace the BC550/560 high Hfe BJT I still need to look around on the market and also the JFet has to be replaced by BJT.
So the lay out still need some adjustment, not 100% ready.
I separated the SGR from the main GR.
I took some of your idea for the layout, it helped alot - thank you!
Soon I'll start to make the PC boards so I can test all 4 VERSION 😱
Power BJT
Toshiba
LatFet
Darlington
Greetings Gabor
Hi gaborbela!
Please give show Top brd in pdf (PCB-top) of the amplifier.
Thank you!
Hello
These layout for LatFet version only!
The tread about HexFet, or Power BJT.
What type do you want to build, please let me know- may be I or someone from these forum can help you.
We must know what do you want to build, already existing material etc.
Greetings Gabor
Audio amplifier BJT with 2sc5299/2sa1943
Hello
Greetings Gabor
Power BJT!
PCB-layot and PCB-botton,
cheers!:cheers:
Ghost22
Bellow version that I am running with 4 or less output pairs.
For 200W I suggest to use 2 pairs of outputs.
BJT:
Do not solder 4 diodes (D1,D4,D5,D6)
Mosfet:
Solder diodes, and replace 2,2r base stoppers with 100R gate resistors.
Some tweak in biasing circuit may be required.
In the picture of my amp there are 2n5xx1 transistos soldered - they are reversed to BCxxx ones. If you need smaller pcb - cutt earth around the board and do not solder the caps next to the o/p transistors. PCB is for 4 pairs, trim the board before for 1,2,3 or 4 pairs before thermotransfer. Amp is very easy to assemble.
For one pair of toshiba mosfets I have build small pcb (removed one driver stage).
  • BG1.2-bjt maly rozstaw v3.pdf
  • BG1.2-v3 top.pdf
    BG1.2-v3 top.pdf
  • bottom.pdf
    bottom.pdf
Ghost22
BJT:
Mosfet:
Hi Borys
Can I use your pcb with one pair 2sc5200/2sa1943.
If could, so can you post this layout in PDF file and Eagle file
Thanks.
The core of the amp is vssa based and this one has good opinion.
What diffrence I found is bottom end is better presented (prapobly due to BJT at output).
The other diffrence I found is the amp without signal is dead quiet.
I think Idefixes was listening this amp bit more than me. I have to finish my speakers first to do proper A and B test. Overal it it very simple and good sounding amp with good kick on bottom end (bjt)
