Pictures of your diy Pass amplifier
F5 half finished
Here's hoping that I've got everything right - one half of it is ready for testing.
Better propective
This photo might better show the relative size of the heatsinks.
The case is a 4U chassis, the toroid is a 500VA unit.
The two big caps are 22000uF Audio Grade caps then feeding a CRC filter with 10 x 4700uF caps.
This amp is only intended to operate as the HF amplifier in a tri-amp setup.
how many fins...
Here is a shot of my newly constructed Aleph J.
The heatsinks are pretty small; each side assembly adds to about 8x10 inches of fins. The heavy aluminium brackets probably help...
I played it recently for 4 hours driving 4 Ohm speakers (KEF 104/2) straight out of the CD player and though it got hot it never got past the 5 second touch rule.
Perhaps I am just lucky so far but I might have done right by keeping the fins up high for good air flow; it was my whole intention with the tiered nature of this scrapyard build.
I'd say be smart and fearless. If it gets too hot you'll have to rebuild. Just don't leave the room while you do your testing :hot:
I've done some assembling and wiring after I got my chassis parts home from powder coating. By the way sorry for the crappy picture quality.
Cutting some Keratherm
Inside
Grinded frontplate
The end result looks very nice, like the blue light coming from it...
Enjoy listening to it !
Walter
