200W MOSFET CFA amp
Damir,
Can you add a noise sim to this (please 🙂).
There is no difference in the noise between 200W//8ohm and 400W//4ohm.
How good is PSRR for this amp and how could be improved in quite simple way. I simulated tree different cases, no any aditional power line filtering, simple RC filter for input stage only, and simple C multiplier for input stage. All this was simulated on + power line only, - line PSRR should show similar results.
BR Damir
After restoring my Adcom 535, building a chip amp, currently working on Richard Marsh's headphone amp, and using the LME49713, I am really hoping you guys come up with something beautiful here for my first big amp project. I'll just sit here and quietly lurk and learn. 😉
Dadod,
You are a mind reader. last night I was thinking about asking you about PSRR.
Would you be able to do similar sims for the simpler (lower LG) version. It would be interesting to see how/if LG affects PSRR.
Paul
Dadod,
Paul
PSRR lower LG version.
Thank you. It shows some minor benefits to the added complexity for the higher LG version. Although these are only at low frequency.
The cap multiplier looks like a easy win. The complexity is minimal and the extra voltage drop could be countered by a small dual secondary transformer added to the main PSU transformer.
JLH in his 80W mosfet amp used +-55V for OPS and +-50V for input stage not to saturate lateral mosfet when they go in very unlinear input capacitance(if I remember it correctly) so small voltage drop(1.2V) on the C multiplier is OK for me.
