I mangoes from Indonesia. I like dx amplifier. I would like to ask, why the final amplifier transistors so hot. if dx is in the power amp transistor amplifier settings for the final heat. thank you
It is not naturally hot dear Manggo...you are having wrong bias
adjustment... search for instructions about how to adjust in this same thread as you are operating it misadjusted or having wrong connections from the heats sensor (BD139) to the circuit pcboard.
This may burn transistors because of excess of heat....usually, in stand by mode, the power transistor temperature never goes beyong 40 degrees celsius.
I cannot instruct you how to do it because i do not remember anymore.... thread is helpfull as for sure i have written how to do it..... i do not remember the method used.
Many amplifiers came after this one...i cannot remember details..... several years ago...uncle charlie is a little bit old (62)...i do not have good memory....my memory is what is written in the thread.
regards,
Carlos
regards,
Carlos
sir thank Carlos for his help. I am sorry to trouble Sir Carlos, I ask his advice, how do I choose a suitable layout dx for me because I am a beginner
regards,
Carlos
Hi Carlos,
I am 61. They say the memory is the second thing to go.................I can't remember what the first thing was.
Carlos sir, please I was given advice to build power amps dx with the layout on the advice of the father Carlos. thank you
My dear friend Radhakrishan T and other people that faced
To Radhakrishnan T - YouTube
Troubles he is having because of different transistors and reduced power supply voltage... the supply voltage is too much low, to use the amplifier this way, we often have to make modifications in some resistor values.
I hope the video gonna help you.
The image attached is the one the friend from India sent me.
regards,
Carlos
regards,
Carlos
Joined 2009
It's better that way 😱
This is the first one, made 6 to 7 years ago
This one was very well accepted by the community.... many guys have assembled in a diy fashion....etching their own boards at home.
Sounds nice...in special for bass....the tone is longer and deep..not controled..loosen...something you hear when you hit an oil barrel...sounds continues for long time..not a metalic sound...more alike a Japanese giant drum you can listen in the movie Pearl Harbour.
Here you have 500 pictures taken long time ago:
http://www.youtube.com/watch?v=42VFnM0zfsU
regards,
Carlos
regards,
Carlos
I will check that out man, is not that is 6 to 7 years long ... it will be forever dear Carlos good things never age 🙂
Juan
Juan
Thank you dear Juan.
I am working into the Armagedon right now... take a look in my video channel.
regards,
Carlos
regards,
Carlos
regards,
Carlos
ok 😀
Juan
Keep distance from Preamplifiers if you can
Some of them can kill your audio quality...try without the preamplifier you have at home...give yourself this opportunity to know what is better to your ears.
Avoid preamplifiers evite preamplificadores - YouTube
regards,
Carlos
regards,
Carlos
hello everyone i want to make an amplifier using 2sc5200,2sa1943 transistor. anyone got the schematic? thank you
This one can use it Vimesh
A lot of amplifiers can use it...almost all them can use it.... there are limits, one of them is that the supply cannot be bigger than 115 Volts positive and 115 volts negative.
Depending the voltage, the current....or in other words, the power, you may need more than one pair..but this is all... installing the quantity needed you can use them with any amplifier.
They are just a power output transistor..... you have hundreds or units that can make the same job.... now a days they are almost the same...more than 10 amperes, more than 100 volts, more than 100 watts... they are alike glass to drink water.... all glass can contain water...considering the case, the size, the capsule, if the case is the same...if they are for audio...and if they are for audio output..then they are almost the same.
regards,
Carlos
regards,
Carlos
Dx amplifier sounds good
This first model has interesting bass response.
Dx Amplifier sounds good! - YouTube
regards,
Carlos
regards,
Carlos
Hi..Carlos..
I was tried building dx blame and i completly parts for my project,i am following the schematic
and pcb from Greg's Web Site
but..the result is not working.when i measure the output line with digital multimeter i read 35v dc more.my question is there something wrong with schematic and pcb layout?what i must to do for the solution?
when i see the top layout there is a note VR2 and R14 not used.is this right?and i see the line from ground to C17.is this a jumper ?thank you very much.
Sorry about my english.I'm a newbie
- Destroyer x Amplifier...Dx amp...my amplifier
