Will linear deliver on promised lsj74
LSK170A=GR (green)
LSK170B=BL (blue)
LSK170C=V (violet)
LSK170D=toshiba never offered this grade of idss
LSK170E=toshiba never offered this grade of idss
LSJ74A=GR (green)
LSJ74B=BL (blue)
LSJ74C=V (violet)
LSJ74D=toshiba never offered this grade of idss
LSJ74E=toshiba never offered this grade of idss
Not to be rude. However how close ?
3 within 10mv. 4 within 3mv. 1 was way off.
so a easy 3 matched pairs.
i used a huge batt bank with 6 cells.
so 13.4v ish
a 1k source resistor.
and, not rude. good question. had i been thinking i would have added that in the first place.
ill post the current of them maybe tomarrow.
i only needed two good matched pairs. so if someone else has some that are close and wanna trade or whatever let me know.
I beleive the standard measurement is; 10Vds, Gate shorted to Source, measure current. However you set up your "jig" or "test fixture", you should acheive the 10Vds and Gate shorted to the Source. Current source, 1K whatever. The 1K is convenient for measureing the current but you should adjust the Vds for 10V. The temp at which you do this is not always specified but generally understood by some to be 25C. Very difficult to achieve without an automated set-up, doing the measurement within about 500uSec of power-up.
:whip:
