DAC-END R (ES9018) full assembled board
Hi inforsit,
I sent this private message 6th August:
Hi Quanghao, I'll be away on holiday from the 17th until August 27th, please delay shipment if you believe the package could get at that time to Spain.
No responses from Quanghao. I sent another private message 28th August:
Hello, I'm back from vacation. You can send me the dac...(continues) Again, no responses from Quanghao. I have paid 966$ for something, I hope.
- The last message from Quanghao on this forum is dated from 17th August 2013.
Hi Raoul,
Hi Quanghao,
You have your "batteries" refilled and ready for work. I need your help to purchase several 4 pins connector (dac board output) because I can't find it myself. I'll be pleased if you can sell me 4 or 6 pieces from your stock, or if you can give me an address where I can purchase myself. Kind regards. raoul.
- Kácsa audió- NEW www.lessloss.com és www.furutech.com
- Then search "rj-140gt".
I'm interested in buying this DAC. Reading back through the thread it seems that there have been some issues. I know this is DIY, and have built other DACs into chassis, wired passive preamps and also built hypex ncores. However I don't have an oscilloscope and electronic engineering is not my thing. I would need to be assured that there is a chance this would be a straightforward build i.e. I don't want to have to mess about with the PCB itself in order to get it to work. Could anyone give me that assurance?
Also is this going to be compatible with my WaveIO? Or is it built specifically for Amanero and nothing else.
Thankyou.
Are you using the DAC module inside a metal chassie ?
Have you got the DAC shield by Qhanghao ?
Are you using the filter on main power ?
Have you tested the spdif output with other DAC ?
Also I would like to know if other person have problem with spdif.
I have similar problem with AES/EBU input. I have the dac build by Qhuangho with the shield. Same source(Brayston DBP-2) works fine with Bryston BDA-2.
44K Redbook is fine.
When I try to play hires, the lock blinks once and the sample rate is showing 0.
