Perhaps - or perhaps I consider ALL amplifiers to be effects boxes. I've never met one that had zero distortion, noise or flat frequency response from DC to light.
It doesn't need to have any of those things. It just needs to have these things below the threshold of audibility, which is an easy task outside of fashion audio.
It doesn't sound like what I hear live.
There is the question, Is HIFI the pursuit of realistic sound?
Or is it measured performance?
Yes the two should go hand in hand. If this was the case then as soon as a perfect measured system is created its job done.
Trouble is Low distortion was done years ago. Was it popular?
Of course it was...then people moved on..LOL
M. Gregg
Please refer to my comments on the forum started by Dangwei about speakers being designed to perform according to one's individual ear. some interesting comments and parallels between the two forums and comments there-on.
Darnit, got the hornets out of stasis again.
Regards.
The sound Man
Regards.
The sound Man
Pano, is it really that difficult for you to put the word "amplifier" into those sentences? As I suggested, try it and your questions will be answered. Here, let me walk you through on couple of them. Repeat after me, "If your definition of High Fidelity amplifier includes just the recorded signal, nothing else, then that's all there can be - a technical fact.". One more, "Why does that have to be the definition of High Fidelity amplifier?If your definition of High Fidelity includes just the recorded signal, nothing else, then that's all there can be - a technical fact. I can accept that as a definition, and a nice one. I loved the "straight wire with gain" idea for years, until I realized "What does it get me?" Why does that have to be the definition of High Fidelity? What's so sacred about the recorded signal? Isn't that just another dogma?
Just so you know, this is "amplifier" section of the forum. But I don't have to tell you that, right?
What's with the strawman argument? 🙄I've never met one that had zero distortion, noise or flat frequency response from DC to light.
They all distort, they all add noise, they all have limited bandwidth and some sort of output impedance. All effects.
Which are those? Do those have names?Some distortions simply aren't audible, even up to levels of 1% or more.
What distortions are those and at what amount do they become audible? And how did you find out?Other distortions are audible in much smaller amounts.
Which amplifier sold in consumer market would be considered as "amp B"?Even tho amplifier B may measurably change the signal more than amplifier A, those changes could be inaudible. The smaller changes in amp B can be more audible, thus the amp more "colored". Closer to the original signal, but more colored - because of the way the ear works.
You listen to the point of amp clipping?It's just that I find some types of effects like distortion, clipping, clipping recovery, noise, etc more audible and more noticeable than others types.
I would like to read about the test rig you used for that comparison.That's the typical "Solid State" sound to me, it sounds electronic, it sounds colored. It doesn't sound like what I hear live.
For hi-fi audio, yes. But to figure that out, there would have to be comparisons. Without it, how do we know how close the reproduced sound is to the reference sound?There is the question, Is HIFI the pursuit of realistic sound?
Measurement would be a visual aid to the design of equipments.Or is it measured performance?
Perfectly measured system deals with distortion only?If this was the case then as soon as a perfect measured system is created its job done.
it does seem to me that progress is being made in understanding each side. I had my doubts there for awhile🙂
Really? I see only groups of people in highly entrenched positions, though I admit that there are some that remain open to arguments, such as yourself.
Sure, I can't argue that. But where is that threshold? Is it the same for everything? And how do I know that the device in question has all those things below the threshold of audibility - wherever that may be? A large suite of measurements might tell me, if I could get them and knew how to read them. Or I might just listen to the thing.It just needs to have these things below the threshold of audibility,
Is it? Has it been for the past 40 odd years? Most of us are old enough to remember the Japanese integrated amps and receivers of the 1970s with the stickers on the front proclaiming 0.0001% distortion - or something amazing like that. Is that as good as amps and preamps ever were? Nothing better has ever been built?which is an easy task outside of fashion audio.
They are named H2, H3, H4, H5, etc. In certain proportions, they are not distinguishable from a pure tone. That's how the ear works.Which are those? Do those have names?
The same as listed above, plus IMD, maybe crossover distortion. I don't know for sure at what levels each harmonic becomes audible. But there is research into the subject going back to the 1920s, at least. That's how I found out about it.What distortions are those and at what amount do they become audible? And how did you find out?
Since I don't buy commercial amps, I don't have a ready name or brand. But a well designed and built SET can have fairly high distortions, and they won't be audible. Achieving that across a range of levels, frequencies and loads isn't something all amps can do, no matter the topology.Which amplifier sold in consumer market would be considered as "amp B"?
It's happened. 🙂 But I do try to avoid it. Do you think that anyone has ever gotten an idea of tube sound or transistor sound from a clipping amp? An amp doesn't have to clip to have colorations, but it can happen.You listen to the point of amp clipping?
My ears, my brain. How else do I know how something sounds? I can estimate sonic characteristics from measurements, but not give a precise description of how something sounds.I would like to read about the test rig you used for that comparison.
But there are probably millions of units of thousands of different amp models that have sufficiently low distortion and noise, and sufficiently high bandwidth, so as to make the audio amplifier a standard commodity part.
I prefer an amp that sounds neutral to me.
If you want to stop "hearing" your amp, take it off the subwoofer!
(Again, amps shouldn't make sound, unless you beat the case or something.)
Probably, if in good shape (no leaky caps, etc.) most of those integrated amps and AVRs sound exactly like most amps built in 2013. There's no logical reason to suspect otherwise. They're not as good, perhaps, for other reasons - reliability, for starters; also would a 1970s integrated have a remote control, or a 12V trigger to turn downstream gear on/off? - but that has nothing to do with "sound."
It does if you put them on top of your subwoofer. The old amps were solid and heavy - gotta sound different, right? 😛- but that has nothing to do with "sound."
Did those figures apply across the audio band at all levels and into all reasonable loads? No? Well, there ya go.
I meant avoiding preferences; just chosen blindly as more realistic sounding.I believe it is known that a significant proportion of listeners prefer some bass and treble boost, and a little low-order distortion. Should that be the new hi-fi?
Perhaps a DBT involving real musicians playing behind an acoustically transparent but visually opaque screen would help. If Pano's 'improvements' really do make a reproduced violin (say) sound more like a real violin then he may have a point. The solution then would be to stop removing whatever it is, rather than adding a synthetic substitute.
I see differing definitions of "hi-fi" (though I think each has valid contexts) so disagreements are inevitable in that situation.
In agreement with the remainder.
And who could ever forget the Yamaha "Natural" sounding SS amps from the early 1990's?
What would posses a giant electronics company to suddenly declare their SS amps to be "natural" sounding?
Also: You can get a "Natural" sounding Yamaha amp with like .003% distortion on ebay right now for next to nothing.
I have just solved everyone's amplifier needs...forever! And at a reasonable price.
Please know I am not serious...but it is interesting to see the claims of very large electronics manufacturers over time.
Those distortions simply aren't audible, even up to levels of 1% or more as you claimed?They are named H2, H3, H4, H5, etc.
So you know the levels at what distortions aren't audible but not the level each harmonic becomes audible?The same as listed above, plus IMD, maybe crossover distortion. I don't know for sure at what levels each harmonic becomes audible.
BTW, this is what you wrote.
Is your writing confusing to you by any chance?Even tho amplifier B may measurably change the signal more than amplifier A, those changes could be inaudible. The smaller changes in amp B can be more audible, thus the amp more "colored". Closer to the original signal, but more colored - because of the way the ear works.
There is research into the subject of hi-fi going back to the 1930s, at least. You should find out about it.But there is research into the subject going back to the 1920s, at least. That's how I found out about it.
Looks like you don't know what test rig is. You could have asked.My ears, my brain. How else do I know how something sounds? I can estimate sonic characteristics from measurements, but not give a precise description of how something sounds.
test rig: definition of test rig in Oxford dictionary - British & World English (US)
Now that you know, would you mind sharing what test rig was used?
Evenharmonics - why the aggressive stance? I've tried my best to answer your questions, but it never seems to be enough. What's up?
Tsk, tsk.Did those figures apply across the audio band at all levels and into all reasonable loads? No? Well, there ya go.
Pano has been unfortunate enough, 😛 😀, to hear systems working properly, so he's not satisfied with the normal "bilge" at much as others are, 😉.
So, either he "learns" to tolerate normal 'hifi sound', or he works out how to get the proper stuff happening, every time ... 😀 😀
Sorry ... 😛
Sorry ... 😛
No, but such devices make it easier to hear the remainder of the distortion from the earlier chain - which could be uncomfortable for some to hear.Looking at speaker types, Magnepan speakers can create an illusion of "being there". Is the signal distorted to create this?
At the recent audio show in Sydney, a Magnepan pair created excellent sound, because it was driven by a very good amp and DAC setup, and normally sourced from music server software - I had no complaints about the SQ at that point. But, when switched to a CD transport the electronics in that unit appeared to generate significant interference - the abhored "digititus" quality was obvious, time to get out of the room ...
After all, this is about amplifiers. No distortions allowed.
And after a short while, they weren't. It's been a solved problem for 40 years.
Remember, you're also talking about the cheap end of the market.
- Member Areas
- The Lounge
- What is the "Tube Sound"?
