What is the "Tube Sound"?
Thanks Johan for taking the time to understand, and to point out the problems.
What I'm saying isn't perfect, but neither is Hi-Fi. If a perfect illusions has been found, I don't know about it yet. Chris makes points very similar to yours.
Very much the latter, Chris. I can't know exactly what the sound was like during the recording unless I was there (that does happen). And I wouldn't expect an exact copy anyway, it always gets manipulated to some extent. I just want a consistently plausible illusion. What I want out of a home audio system is is for it to convince me that what I hear is real, over and over again, across many recordings and musical styles. The system should also allow me to hear the differences in recordings, the ambiance of the venue being a very good clue. Such systems exist and I don't remember hearing any that contained "effects boxes". What a system like that gives me is a strong illusion of reality, that's what I want. And when the recording isn't "real" - say anything from Switched on Bach to Justin Bieber - the results are still plausible, as tho something like that could exist. It's an illusion. I hear people talking and singing every day, I have a good idea what that sounds like. Many audio systems don't reproduce that realistically. I want one that does. Same for guitar, tuba, piano or drums - they should sound real.
As for "Tube Sound" - I've picked Solid State over tube amps in a few blind tests, because I thought the SS had more of a "tube sound." 😱 I.E., more natural, better timbre, less fatiguing, better reproduction of the recording acoustics, etc. Those are things I've often heard tube amps do better than solid state, so that's "tube sound" in my mind. Like many stereotypes, it ain't all that accurate. Certainly other people have other ideas of what tube sound is, that just happens to be mine.
In brief, one amp might be doing all sorts nasty things to the signal, but if I can't hear them, so what? I'll still prefer that amp over another that makes fewer changes, but changes that are audible and annoying. It's the final result that matters to me. What I hear.
Is it a case where you may prefer tubes over SS based on speaker type choosen. I do notice most horn speaker types favor tubes over SS , where as large dynamic speakers with complex loads favor SS..
Pano said:
Do more subtle, unintentional encodings exist? I argue that they do, and are present in almost every recording.
Then to correct for them you just need to know exactly what they are. You don't know? Then you can't correct for them. Equalisation is a red herring, as there we know exactly what has been done so we can exactly undo it.
If the illusion is made more convincing, how can that be wrong?
I didn't say it is wrong; I said it isn't hi-fi. One is a moral judgement; the other is a matter of technical fact.
Facts:
-Valve physics and circuit topologies tend to result in lower power amplifiers that have a higher THD+N than SS amplifiers, but with distortion largely comprised as low-order harmonic distortion, primarily 2nd-order for SET topologies and decreasing odd n-th order for PP topologies.
And, at least at levels within the normal operating range of the amp, the audibility of distortion at those orders and those levels is very much in question. THD is known to correlate very weakly with, well, anything.
However, SET based amps often have another, clearly audible form of distortion: rolled-off frequency response. For example, here's a Jadis amp measured by Stereophile into a resistive load, and into their simulated loudspeaker load
IOW, it rolls off on the low end like a cheap AVR with inadequate power supply into a resistive load, and has about 3dB of midrange variation into their simulated speaker load.
Nothing about orders of distortion is going to be more audible than those glaring flaws.
-SS amplifiers, due to the almost mandatory use of GNFB, have more interphase distortion. The distortion generated by SS amplifiers is of lower magnitude but listening tests (non-objective) have identified it as being "harsher" on the ears compared to valve amplifiers.
-Due to being lower-wattage, valve amps beget high-efficiency speakers. Class-A amplifiers operating with high-efficiency speakers tend to sound good! Operating in a the "first watt" region (thank you Mr. Pass) most of the time where the amplifier is highly linear. It doesn't matter if it's tube or solid state.
These points belong under your psychoacoustics/marketing bullet, really, because these effects have not been documented in serious listening tests.
-Psycho-acoustics is real. ***
Yes. So is the power of marketing to influence what one thinks real.
Completely made up: Tube warmth,***
The others you mention are idiot audiophool buzzwords with no meaning outside the world of marketing/propaganda, yes. However, it should be obvious by now that "tube warmth" is simply a shorthand for the midrange frequency response errors (3dB swings in the above SET example) caused by the interaction of the amp's source impedance and the loudspeakers' impedance.
Class A and frequency response are two orthogonal characteristics of an amplifier i.e. they are quite unrelated.
Most valve P-P are effectively Class A most of the time, as the quiescent current is a significant fraction of the peak signal current. You could argue that they roughly correspond to 'first watt' SS amps, but with much less of the 'next watt' distortion which is inevitable with the 'wrong' quiescent current. Fortunately SS uses NFB to hide this.
If you are saying that what you are really looking for is a modification (or, to put it in a way that sounds a little more pejorative, a distortion) that produces a plausible generic sort of "concert hall sound," then it does seem that you are asking for an effects box that creates the illusion of reality.
If only it were so simple, Chris - I'd be happy! 😀 Alas, reality isn't always so simple. But I don't have to tell you that.
If all I needed is an effects box to add some generic "concert hall sound" I could go buy a Lexicon reverb and be done with it. In fact I do own an effects box, the good old Yamaha DSP-1. It adds reverb - some of it sampled in real halls - to 4 effects channels. It's nice, it's fun, but it's always just a little too artificial. The setting I found myself using the most was Dolby Stereo, which is basically just the out of phase info folded back into the rear speakers. That's what sounds the most natural to me.
I am looking for an illusion of reality, that's what Hi-Fi is to me. If the perfect signal brings the closest illusion of reality, great. But does it?
Ah! And there we get to the heart of the matter. If your definition of High Fidelity includes just the recorded signal, nothing else, then that's all there can be - a technical fact. I can accept that as a definition, and a nice one. I loved the "straight wire with gain" idea for years, until I realized "What does it get me?" Why does that have to be the definition of High Fidelity? What's so sacred about the recorded signal? Isn't that just another dogma?
But I really don't care what happens to the signal as long as the resulting sound is accurate to what I know as the sound of instruments and voices. Why should I care about what happens to the signal? Basically, what does it do for me? Why is a wire with gain better than something else? That isn't necessarily a technical question, perhaps more of a practical or philosophical question. For music playback - Why is a strict adherence to the signal "better"?
WOW! For a commercial 300B amp, that looks really bad. Nice to see an honest review that actually reports shortcommings in an amp.
I wouldn't be surprised if my 6P1P SE amp has better performance than that 300B, although it has less output power.
I'm certain my 6P41S SE amp would outperform it.
I don't really understand what you are wanting to say. Seemingly you agree that you are looking for a distortion in the amplifier that gives an illusion of greater realism (not "true" realism, since you have agreed that it will not recreate the specific "reality" of the actual performance it is reproducing). I don't understand why you balk at calling this an "effects box." Is it just because that is a slightly too stark and brutal way of describing what you are seeking?
Chris
Here is a thought,
Looking at speaker types, Magnepan speakers can create an illusion of "being there". Is the signal distorted to create this?
If the valve equipment can help create this, is this also distortion?
If not its lost information from the source.
M. Gregg
It is all we have as a record of the musical occasion. Anything else is guesswork at best, and preferred personal embellishment at worst.
Yes. Anything added to the signal is distortion. By definition, anything in the output which was not in the input is distortion (or noise).
Magnepan,
Does not sound like distortion.
However does it sound like a reference? Because if it doesn't the HIFI industry is stuffed!
I would rather listen to (High end ) Hifi, than perfect measured sound that might sound like a disco!
Because you have to ask yourself, is the TISS TISS, thump thump. Correct signal? Ie good measured performance. If it is then ANY roll off is an effects box, including record warp. because its in the source signal.
M. Gregg
Are those the only two options we have?
No. Record warp is a form of interference. The groove information is the signal. Filtering out warp is the same as filtering out unwanted RF.
I'm hesitant to enter this thread, because I don't have a dog in the fight, but it does seem to me that progress is being made in understanding each side. I had my doubts there for awhile🙂
I can side with Pano as I see him viewing a bigger picture of the listening experience, from recording to ear/brain, and desiring a true-to-life replication.
I can side with the succinctly phrased, "[The recorded signal] is all we have as a record of the musical occasion," and the wire-with-gain ambitions.
Ideally there shouldn't be a conflict between the two.
But there is... that is why DBT's are important IMO.
Pano, are you in a sense (by way of analogy) claiming that artificial banana flavor tastes more like a banana than a real banana?
Dave, is it possible that "preferred personal embellishment" could be chosen as more realistic-sounding by a large and statistically significant portion of blind listeners, therefore be not so personal?
I believe it is known that a significant proportion of listeners prefer some bass and treble boost, and a little low-order distortion. Should that be the new hi-fi?
Perhaps a DBT involving real musicians playing behind an acoustically transparent but visually opaque screen would help. If Pano's 'improvements' really do make a reproduced violin (say) sound more like a real violin then he may have a point. The solution then would be to stop removing whatever it is, rather than adding a synthetic substitute.
Perhaps - or perhaps I consider ALL amplifiers to be effects boxes. I've never met one that had zero distortion, noise or flat frequency response from DC to light.
From the electronics chain, yes.
They all distort, they all add noise, they all have limited bandwidth and some sort of output impedance. All effects.
The problem comes in thinking that all these "effects" are created equal. They are not. Noise will be more or less audible depending on its spectral make up, not just its average level. That's why noise measurements are often weighted. Some distortions simply aren't audible, even up to levels of 1% or more. Other distortions are audible in much smaller amounts.
Even tho amplifier B may measurably change the signal more than amplifier A, those changes could be inaudible. The smaller changes in amp B can be more audible, thus the amp more "colored". Closer to the original signal, but more colored - because of the way the ear works.
I prefer an amp that sounds neutral to me. Assuming that I want an effects box assumes that I want some sort of audible coloration. Not true. It's just that I find some types of effects like distortion, clipping, clipping recovery, noise, etc more audible and more noticeable than others types. That's the typical "Solid State" sound to me, it sounds electronic, it sounds colored. It doesn't sound like what I hear live.
