Does anyone know what he's been using for speakers?
I think that's a pretty important part that factors in to overall amp/speaker performance. Comparisons can be simplified to 2 amp types and 2 speaker types:
Amp A: Tube
Amp B: SS
Speaker X: Low efficiency, high mass cone, low Q
Speaker Y: High efficiency, low mass cone, high Q
Possible combinations are:
AX
AY
BX
BY
I would speculate only one speaker type has been used for the test. It would be interesting if I were mistaken.
According to his web site he (1) has a variety of speakers available, and (2) the subject may bring their own speakers if they prefer.
He does require thet they use dynamic drivers (I presume this rules out electrostatic speakers).
And I beleive he requires the same speakers be used by both amps.
Why build SS amps? They tend to be more sensitive to RF interference. They are more complicated, for a given performance level. More likely to fail if the output is shorted. 😎
Really , i drive mine (ss) into a short circuit everyday ...🙂
Jeepers.
I think of the Williamson amplifier with a frequency range of up to 300 kHz, Leak, Quad II and Mullard 5-20 also way up (power amplifer only) .....
I refurbished two ST70s a long time ago, but cannot remember things being that bad. H.f. response unregulated by nfb to the point that it falls inside the audible band ..... 😱
If you read the stipulations of the Richard Clark test carefully, you will see that equalisation is applied if necessary, in order to match the frequency responses of the two amplifiers in the audible range. In the event that the tube amplifier had a sufficiently flat response that compensation was not needed, then it would not be used.
Chris
And he started to allow car speakers after 2005 or thereabouts. In the pdf gk7 linked earlier, the speakers used were not reported. It would be interesting to know if Clark has also demonstrated no difference in amps for speakers on different ends of the spectrum of driving requirements. Until then, "all the same" is limited in scope.
It would be interesting to know if the mid boost knob labelled "tube sound" on the Buttler unit was upstream or downstream from the distorting tube. If it's upstream, it might make sense that they decided that it sounds better to distort the midrange frequencies first. So it's a distortion control first, and a frequency selective one second, if that makes sense. The Clapton "signature stratocaster" guitar use to have a mid-boost knob on it, active battery driven, with allegedly 20dB of boost centered around 800HZ according to his sound man (Dickenson). Maybe that's what a guitarist prefers when they are going to solo. Get rid of the delicate strat sound and get manly...Reminds me of a Butler "Tube Driver" amp I once saw. I don't know the specifics of the circuit (and don't care) but it had a solid state amp section with a tube somewhere in the input. It also had a "Tube Sound" knob, which according to the marketing propaganda varied how much of the signal went through the tube. Turn it on, and sure enough there's that warm and inviting tube glow. (There's a reason that many higher-end restaurants have gone back to "Edison" style incandescent bulbs for their lighting!)
But guess what the "tube sound" knob actually controlled.
If your guess was something other than "a midrange EQ boost, as is typically what would happen with a low source impedance amp driving loudspeakers," well...you would simply be wrong.
Subject to the basic stipulations listed in the challenge, the contender is free to choose the amplifier, speakers, etc. in whatever way they feel will maximise their chances of winning the prize. Of course only the amplifier is swapped in the A and B double-blind testing, but the challenger can specify the choice of speakers that will be used in the test, within the stipulated limits.
Chris
... In the pdf gk7 linked earlier, ...
The pdf I posted is from an ABX test Stereophile conducted, it´s not related to the "Clark challenge".
Ah alright then. Are the speakers listed on another page for that article?
cnpope said:Subject to the basic stipulations listed in the challenge, the contender is free to choose the amplifier, speakers, etc. in whatever way they feel will maximise their chances of winning the prize. Of course only the amplifier is swapped in the A and B double-blind testing, but the challenger can specify the choice of speakers that will be used in the test, within the stipulated limits.
I understood the rules before posting. The question is whether the EQ/output impedance adjustments are effective for all speaker/amp interactions or if these adjustments are just effective for a subset of speaker types.
My testing with an oscilloscope supports what Bob Richards says. I fitted a resistor across the output of the amplifier, audio generator and ran the amplifier at full power and a little more so that the sine wave showed the flat tops you get a little above maximum power. The difference can be seen in how sharp the junction between the flat distorted bit and the sine wave is. The transistor amplifier had sharp corners at the point of distortion setting in. The tube amplifier had rounded corners at this point. So when the transistor amplifier is over driven the transistors hit the limit where signal meets the power supply voltage very hard. Tubes have a much softer landing at this point with rounded ends to the flat bit. At lower power levels there is very little difference between the two amplifiers if any at all. My conclusion is that the tube sound can be had when the amplifier is driven close to the limit. No wonder guitar owners like tube amplifiers.
According to that, there was one person (believer) with a 94.4% probability of being able to distinguish between amps in an ABX test and one skeptic with an 84.4% probability of being able to distinguish between the two amps in an ABX test.
(The probability of being correct is 1 - "probability due to chance".)
You are referring to thisAgain, I don't know what you mean. You seem frustrated with me because I'm not answering your questions the way you want. Is that spin? But honestly, I simply don't understand much of what you are asking. Like the sound waves thru and amp and such - I just don't know what you mean. 😕
What I've tried to do is express my point of view and my experience. I've tried to explain that they may be different from yours. If your only definition of Hi-Fi is no alteration to the signal, OK, I understand, it's a common one. It's not the only one tho, that's my point.
and I replied,To you. That's how you have defined it. High Fidelity to the signal that was decoded by the player. That's not a bad choice, it's a great starting point, but it isn't necessarily my choice. It used to be until I found that strict adherence to the signal does not always result in sonic realism (for me).
Therefore my definition of High Fidelity is fidelity to the original sound, not always to the original signal. If the two coincide, all the better. I don't find that they always do, and I know that I am not alone in this.
You see, Pano, your statement "fidelity to the original sound, not always to the original signal", is incorrect when describing amps. With amps, it is always about the signal. Signal goes in and signal comes out. That's what amps handle.Except for the loudspeakers, what other ways do electronic audio components work besides sending electronic signals?![]()
It helps to use quotes when responding to what you think someone stated.If your only definition of Hi-Fi is no alteration to the signal, OK, I understand, it's a common one.
How many sessions was that test done by that person and what was the setup condition like? Has he been able to repeat that in other ABX?According to that, there was one person (believer) with a 94.4% probability of being able to distinguish between amps in an ABX test and one skeptic with an 84.4% probability of being able to distinguish between the two amps in an ABX test.
How many sessions was that test done by that person?
Note that this was a test of the Counterpoint amp, which blew up during listening. They were notorious for being unstable, and that could certainly be audible. The pdf gives the number of trials, if that's what you mean by "sessions."
Sort of but if my memory serves, they wanted him to try again but didn't pan out that way.The pdf gives the number of trials, if that's what you mean by "sessions."
The test of Futterman vs Pioneer also shows a significant probability of being able to discern a difference (84%).
That's actually not particularly a good number (and it's not quite how you defined it)- generally, a 95% confidence is required for something to be thought of as probably significant.
Nonetheless, I wouldn't be surprised if in a test of a few more people, you could hit a 95% confidence with the Futterman, since it has a relatively high output impedance.
I agree that the numbers do not give strong confidence in the results.
That said, they are interesting in that they may present some results that are counter to the tests Clark did.
Then again, if he is correct, they may not have adjusted the amplifiers within the required matching for levels and that according to Clark would have been enough for the results seen.
In addition, I believe Clark would have adjusted the output impedance of the Pioneer to match the Futterman which might effect the results as well.
Exactly so. Into a real world load, changes in amplifier output impedance cause changes in frequency response, something to which humans are demonstrably sensitive. That can sometimes be simmed with a resistor, but in some cases (high output impedance that varies with frequency), you have to get a bit fancier with cheap Rs and Cs to get a good match.
IIRC, the distortion components didn't change at all. IOW, the knob did absolutely nothing except for control the level of midrange boost. (Prof. Ken Pohlmann bench-tested the amp in question for a magazine.)
Also, this boost was centered about 2 octaves up from the boost in the Clapton amp you mention.
- Member Areas
- The Lounge
- What is the "Tube Sound"?
