100W Ultimate Fidelity Amplifier
Hi mr mile i built ur ax14 but i have a 7volts dc offset. Ive used c3281 and a1302 the drivers are c2073 amd a940. Previously.ive used kse350 n kse340 replaced it with mse still same dc.offset. i also rrplaced q1,q2 n q3 still same dc offset. Please help. Thanks
try to probe the correct pins of your transistors. pins should match the pcb layout. i experienced this dc offset when my transistor has different pins specs than the pcb layout.
goodluck.
I made some small changes to ax11 amp - as sansui au217 amplifier (preaty same amp) and have smmall question - can the input buffer be bypassed and input pair be substituted with 2sk170 tranies ?
I have made some simulations and amp is preatty quick and looks stable.
The square is 20kHz
THX
