My_Ref Fremen Edition - Build thread and tutorial
My_ref_FE built and working
Hello,
this is just to thank Dario and all the people involved in the development of the board of such a wonderful ampli 🙂.
Yesterday I've mounted my boards (first group buy) with the mouser bom and both worked impeccably.
Some info:
- before mounting each component, it could be obvious, I checked it (measuring the resistance, checking diodes, reading types on transistors, etc) and, lucky me, I found no error at all from Mouser.
- I'm using one trafo (22V+22V, 350VA) from LSP transformers (Italy). My speakers are 4Ohm nominal (AR 312HO),
- the picture shows the boards and the trafo of the first "run". I'll put everything in the galaxy GX288 enclosure very soon.
Thermals
The construction went on in a troublesome manner until it was time to solder the thermals. 70 W Goot PX-251AS soldering station definately failed to heat thermals. I have been using this station for a few years. Mostly for digital PCBs with small pads and thin tracks. But even then I suspected that the temperature of the tip was not up to the numbers on control dial. With the thermals, at 400C it was like mixing butter with a spoon. Most problematic thermals were R104, R201, C1, C2, C9, central contact of relay. And the tutorial warns that the major trouble is still ahead with C101, C201! So, one way out was to use ancient irons. The ones in the picture are 90W, 65W (both with 10 mm wide flat copper tips) and the Goot product for comparison. The 65 W was enouh to do the job. It turned to be more efficient, then the 70W ceramic type... Now, I certainly can not recomend anyone to use these type of irons, mainly because they are considered not safe to use with semiconductors. Soon we'll see if I got away with it, or not... In future I will be searching for another solidering station.
