Masterpiece
I agree that current inputs can sound a bit dry, and they do need some "input" impedance.. the rolloff is strongly circuit dependant.. the circuit I play with now changes 0,2 dB at 20KHz with different cartridges.
Anyway, its just fun to play with these circuits.. funny how many ways you can get good sound out of the grooves. 🙂
Sure, now that my Atlas, my Olympos and my Titan are gone to the HighEnd in Munich i am back to my modified MC 30 Super. I also gave Martina my Stille Phonostage so i am back to my tube transimpedance phono stage. I thought why not using my LA Audio mono blocks then so the first time i have a complete tube system. Sounds great too.
Will try the new mundorfs... do not know f I can get the "special" micas but IMO micas are ok for the 500.5Hz but too much sparkling for the highs were I use mostly small styrenes as "fill in" bypass.
Used to like the shinkoh for cart rload but now found the new vishay bulk metal to give even better results.
For the 500.5Hz resistor I really like the kiwame carbons.
Thank you for the tip: PF1262-5KF1 Riedon | PF1262-5000-ND | DigiKey
What resistor type are these ?
