F5 Turbo Circuit Boards
Impedence plot
Any opinions ?
post2103:
is that 70degrees of phase angle at 4ohms @ ~40Hz
& ~45degrees @ 3ohms @ ~60Hz?
Those will be very demanding of the output stage and drivers with short term loads.
At 40 to 70Hz the tones could be quite sustained. Could high levels of these bass tones these blow up the output stage?
post2103:
Yes Andrew, that's the way to read the graph!
Hence ,my question: As much Power into 4 ohms as possible (higher rails) or as much "class A" as I can get from lower rails ?
Andrew,
I am totally willing to have a closer look, your indications don't help me though.
Could you tell me what you mean by SOAR - I am pretty sure not a jordan village or cognitive architecture.
If it's "Safe Operating Area" then I would just need a hint on where to find information on Bensen.
Thanks,
Max
:sarge:
Usual Excuses: Family Issues, Day Job, other PCB/chassis issues...
BUT the circuit board sets are now individually labeled, packed and SENT by UPS to the order fulfillment center. Should get there in 2 days plus 2-3 days processing on their end and they'll be in the store. The fulfillment people are more reliable then I as it IS their "Day Job"
Thanks ....
output circuit board dimensions ...?
Any opinions ?
Yes ...
post2103:
Not if he runs enuff and keep them within SOAR....
Your amp will have to be able to sink power continuously into 2 ohm to not have bass issues when driving that load, noticed you have the port tuning at a low 20hz, what size driver ... ?
Thanks ....
Yes ...
Wayne,
quoting you " if he runs enough ****" , I guess you wanted to write bias "bias" ?
Driver is 15"
Max
