Unfortunately its in Russian which I cant read. Try
The Buffalo-IIISE (Stereo Edition) 2-Channel DAC
its quite famous in diy circles costly tho. There is a ebay seller diynhk
ES9018 32bit Audio DAC PCB kit | eBay
vinodt1347 musicality of this device and the Dac (ES9018) overdone and inflated as producer (great marketers bother) and manufacturers like Buffalo and other (audiolab). It sounds like a typical Dac average (not like the cheap of course).
and I repeat, does anybody have a measurement of DAC7 or DAC9 (by Weiliang) in RMAA or others???
there was a circuit of dac.Unfortunately its in Russian which I cant read. Try
Got a little question:
How many of these Klick do I need to replace the opamps of a DAC 5?
Looks like there are two included but what is the sense of that dual to mono adaptor?
2 pieces, the sound is much better
DAC by weiliang with possibility to disable digital filter and interpolation
To weiliang:
Hi weiliang. I want to buy some DAC from you.
Condition is that "data" will by passed through DAC directly to analog without any interpolation, oversampling, under sampling, without any use of digital filter.
I want to use DAC to measuring purposes. I need that exact digital value of input will do exact voltage or current value on analog output, include DC value of course.
This can be done by software setup (by windows) or hardware setup directly with pins on DAC chip. I can do both.
Please recomend.
To weiliang:
Please recomend.
audio dacs are not 'instrumentation dacs'. they dither (as one post-process step) and try to make the wave sound 'good'. this is not the same job as an HP or tektronix measurement dac.
not sure you will be happy with audio dacs. depending on how much resolution you expect, of course.
Hello,
I got a little problem with my DAC 5:
Always when the deep tones come, the highs sound strange. They're sounding like the DAC got out of power and very fading...
Already ordered some OPA627 but I don't know if they'll solve the problem...
You got any advice for me?
In addition the left Channel is a bit louder than the right channel, but I might be wrong with that cause that's subjectively...
It just sounds like the deep tones are mixed with the highs and that sounds very strange. Sorry for the description, it's very complicated to describe that sound
weiliang , you have to put in the first post or theme for each DAC graphics like these http://img04.taobaocdn.com/imgextra/i4/647667811/T2zvDFXeVaXXXXXXXX_!!647667811.jpg
It's great to add credibility to your devices. =)
9018 DAC
Thanks, starting to save my money.
Torrodial or 2 rcore???
Hello friend,
ESS9018 is the best,it is my latest design.you can find it from my online store.link here:ESS9018
weiliang
- Digital Source
- WEILIANG DAC5 - WM8741 & Tenor TE7022
