6V6 line preamp
Joined 2011
Same thing 128 spectrumbins
Why not, its a test bed, looks come last. Did you manage to listen to it or put it through scopings and the HP analyzer?
It performs flawlessy and i tried a few different setups like CCS but went back to resistor load.
The basic and simplicity is the beaty of it.
Basic current regulated heaters starved untill i got best performance.
Early SSHV board forced to become a later version.
I really like it.
Performs very well with non exotic parts.
A descent chassi is on the list of things......the endless list of....
Its the standard common cathode 15dB gain design? On what system and with what vintage 6V6s you listened to it? I preferred the passive load to CCS also back when I was researching options, its in the older postings.
I tried several 6V6 and right now it´s a couple of RCA blacks in there.
The older russians are good value for the money.
It´s been hooked up to all kinds of amps including SS.
Why the first pdf has no harmonic noise and the other two a lot? Is it exactly the same circuit measured or it combines an amp?
First pic is loopback showing baseline at output level to measure 1W performance of amp. I have some 60hz niose, but it was do to crappy test rig.
As for 6V6, RCA blackplates is my choice as well. New Tungsol was very good( have matched quad for diff version), but Military grade RCA was worth money and this amp is worth the upgrade.
