@ Barrows
What did you need to do to replace the 100uf with .1uf film? Did you need to change the circuit in order to do that?
Thanks,
Mark
Thanks,
Mark
Thanks,
Mark
No changes, I just installed the .1 uF films instead of the 100 uF electrolytics. I mentioned this on TPA forums, and Russ White recommended not going below .1 uF in those locations. The Salas regs do not like to "see" lots of capacitance at their outputs (unless one adds additional damping to the regs themselves) nor do they seem to need it.
Hi Salas
I am planning to power a BelCanto CD2 with a bib.... This CDP is normally powered by an external wallwart 12 psu specked at 0.5A max output.
I am having difficulties finding a schematic of the CDP so I do not know it's power consumption... a guess would be welcome.
Hi Salas
Easy put 100 ohms resistor in series and measure real consumption with DVM and ohms law to calculate.
Mmm, that might work on a HV low current devise.
Ohms law: U=R*I
Voltage drop over a 100 ohm resistor at 0,5 A is 50 volt. Not so good for measuring a 12 v supply😉
make it a 1 ohm if using that method
Thanks for this information. Yes, I suppose the TP designers were not necessarily thinking of this particular power supply when they designed the Legato.I would also experiment with the onboard decoupling caps on the Legato (the 100 uF electrolytics), I changed all of them to .1 uF films
100-150mA extra would fair bit better
I want to use conservative values to keep the heat down, but OK, I will go up to 100mA shunt (still at 13V).I run my Legato with +/-15 V rails, and shunt around 160-200 mA. I feel the Legato sounds better at 15 VDC.
Now could someone check my calculations, please?
The DC-in will be 18V, target DC-out 13V.
Let's just focus on the negative rail - 190mA Legato draw + 100mA shunt = 290mA CCS. Thus:
- the R101 current setting resisor should be 12.7 ohms? (But 5W resistors are easier to buy as either 12 or 13 ohms).
- In the voltage reference section I will have 2x red LED's, a 1.8k resistor, and no diode,
so the R105 initial voltage trimmer value should be 500 ohms?
Thanks stajo, let us know if helps Ricardo?
Ohms law: U=R*I
Will do
- the R101 current setting resisor should be 12.7 ohms? (But 5W resistors are easier to buy as either 12 or 13 ohms). If you use 13 ohms you will not have the necessary current, if you use 12 ohms you will have a little more of necessary current, if I was you I choose a little more of extra current
so the R105 initial voltage trimmer value should be 500 ohms? c. 10V-25V Mosfet reg. 2 1.9V LED, 1.8 kOhm R303. 5K trimmer. Other parts jumper (as per BiB pdf guide
I need help. My target voltage is 24V, I have 30V in, but the max voltage I can get is 14v.I use 4 green leds and 2 red leds, the trimmer is 10k ohm with 220ohm. I try for r101 10ohm and 100ohms, it change the max output volatge from 14v to 13v. The jfet idss are about 4ma. Now I don't know what to do.
I tried 680 ohms, 2,2k ohms and 340 ohms as load and have always about the same result, the max output is always about 14v. Is it possible that thet the mosfet are faulty, because I have the same problem on others board too ?
Some semi must be faulty or the wrong type. First time I hear about this difficulty. Is there 120 Ohms Rg to the output Mosfet?
4 green + 2 red leds will give aprox 11.5V, the 220R gives another 1V. IN which case, if you want a 24V output, the trimmer will need to make up approx 11-12V. What is the voltage across the trimmer when you have a very light load?
Do you mean the value of r106 ?
I have 9.6v across the trimmer when tunr to max with 680ohm load. When I reach the max voltage output, I can stiil turn the trimmer but the voltage doesn't increase afetr 14v. The ouptu mosfet is irf9530n. does it make a deifference ?
That one is bit beefier but has +260pF Ciss +70pF Crss above the standard. Not sure if it could create a functional problem but I don't like it for performance a least. Don't remember the designation right now, talking that resistor very near to the left most leg of the output Mosfet. Check that out for right value, make it half value, piggyback one the same, see if something changes.
Thanks for that information merlin el mago.
By the way, I will have the chance to see Barcelona/Catalonia this September!
I have another question: I'm a bit confused about the choice of capacitor for C101/C102.
For voltage reference I will be using resistance (2x 1.9V LED, R1.8k + 5k trimmer) not zener. The build guide says -
"A fully resistive choice can have smoother and lower noise spectrum to filter and lends for C102,202,302 MKT 4.7uF-10uF. 10uF filters better. Electrolytic 220uF is even more efficient a filter for sensitive digital and MC phono stages"
Given my situation - an I/V stage drawing a fairly constant 180mA per rail - at C101/C102 should I use 10uF/50V MKT or 220uF/50V electrolytic?
You are welcome to Barcelona you will not be upset with the visit and surely come back again.
With my Legato I/V I use 10uF 200V Auricap MKP and sounds wonderful😉
Enjoy
Felipe
- Power Supplies
- SSLV1.1 builds & fairy tales
