Thanks Bas, maybe I will start looking out for a cheaper choke option....
GZ34, any other tube recitifiers that you could recommend that could handle the current demands of the babyhuey?
Hi surfstu, I am using a 5R4. Basically anything that can handle 200mA.
Verstuurd van mijn GT-N7000 met Tapatalk
Thanks Bas, if you have a schematic available for your psu with the 5r4 I would love to see it....
Stuart
Stuart
will the choke make a noticeable difference? I'm planning on a similar supply for the early ecl86 baby huey design but the Lundahl chokes are near £150!
and why does no one use the GZ34 for rectification? I only ask because I already have the octal socket for it in my chassis....
Hi Surfstu,
I got mine from here
HT Smoothing Chokes
Also keep an eye on Ebay 😉
Thanks Soonerorlater,
would I need a choke greater than 100mA? I presume so...
seen a nice vintage 17H 160mA that i could buy
would that be too little?
it will be running into 4 x ecl86 PP UL amp with approx 30mA running through each tube
Current wise you should just about be OK for 4 X ECL86's.
IIRC the choke spec was 5-10H. Perhaps you could model your power supply in Duncan to see how the increase in inductance changes things.
For me, vintage means "used". Of course if this vintage choke is dirt cheap.............😀
Thanks, I,ve just started using PSUD2 as of yesterday...
was a little confusing for a noob but I,m getting there... I don't think the 17H should be a problem, just hope that 160mA is ok.
There is also a nice quad 2 choke on the same site for sale, kinda like the idea of that, just need to find some info on its rating...
Just using PSUD2 now to try and workout if I can use the spare heater filament supply (6.3V) and convert it to 12Vac or 12vdc, to power some chinese VU Meters tha i just bought. The driver board requires either ac or dc at 12v.
Stu
Stu
Has anyone built,
the amp in post 1261/1262 of this thread?
And used off the shelf power Tx and good OP Tx?
M. Gregg
M. Gregg
The rest of the Jessica Amp for info
Note this was a 6V6 + 6SL7 version.
Ian
Page 127 😀
Update for interested parties...
Hi all,
Just a quick update for those that are interested.... 😀
Well I finally finished the main amp today and fired it up with 6V6's (my plan is to use 6F6's). Wow!...this little amp sounds just amazing! It's way better than any amp I've previously built and it's dead silent with no signal (I measure 0.0001mv rms hum at the speaker). OPT's are custom electraprint's 20 watt 10k to 6 ohm.
I deviated from the PSU slightly. The negative supply uses a voltage doubler fed by the two 9v windings on a toridal to get -48v. This allowed me to wind a heater winding on the torid for the 6sl7's.
The only problems so far is that the 6v6 bias pots (50k) are fully wound and I can't drop the current below 42ma (they started off at about 100ma at very first power on!!!). The balance pots (100R) are also fully wound to one side and only just come close to balancing....
I'll take some more measurements over the next few days but the sound is just fantastic! Thanks Gingertube! 😎
Hi all,
I've been checking my voltages and the -48v supply is actually at -38v supply. I will need to make a few tweaks tomorrow to increase the negative supply....
Hi, I have alle the parts for building the 6V6/ECC83 with mosfet driving the 6V6. I just need to know, does it have to be a blue LED for the voltage referance in the input diff. circuit?
Where does the name Baby Huey come from?
Also there are many small parts in this amp, have you build PCB for it or how do you handle alle these small parts, glued them to a piece of wood or how do you handle such designs?
For the small parts I used perforated pcb. Not sure what you call it. Looks like pcb with lots of holes. Most electronics shops have them.
Hylle,
Baby Huey was a comic book character,very large and immensely strong (for a baby).
Hence the name. I have run this little amp up against BIG Amps like Aranov LS9100 120W Monoblocks, Jadis JA80 80W Class A Monoblocks etc. and while it won't go as loud as some of those it kicks their butt sound quality wise. As far as sound quantity goes it has the bass authority of an amp with X2 the power.
The Blue LED is the Voltage Reference for the current source in the tail of the diffamp.
The "quality" of the current source (it's output impedance) is a function of the beta of the bottom transistor and the value of the emitter resistor. For a given current that resistor increases in value as you increase the reference voltage at the transistor base., so I maximised that voltage by using a Blue LED. It doesn't have to be Blue, It will work well with Green or Red LEDs but since the reference voltage is then lower the emitter resistor will need to be lower and the current source will not be quite as good. Would you be able to notice the difference? I don't really know but I suspect you may not. An alternative is to not use a LED at all, but use a reverse connected NPN transistor with open base as a "low noise " approximately 6.8 volt zener. (Connect the NPN reference transistor emitter to the current source transistor base, connect the reference transistor collector to the -ve supply where the current source transistor's emitter resistor goes, leave reference transistors base unconnected AND limit the current flowing to say 1mA max so that the reference transistor acts as a zener rather than just blowing up.) That arrangement is shown on one of the posted schematics and it is one I've used several times and found to work well.
Drewaudio,
The "Rule of Thumb" for the negative supply on the source followers is that it needs to be a minimum of about 3 x the bias voltage. This allows the signal to swing up to 0V and down to 3 x the idle bias which will certainly be enough for the tube to go into cut off for normal Class AB operation. For an EL84 idle bias is about -12 V and a -38V rail would be fine. For 6V6 you will probably want a bit more. Measure the bias voltage at idle and then do the X3 calc, or just check with an oscilloscope that you have enough voltage there to run the tube into cut off (zero current). Note that you do not want to be running the source follower into cut off. Mosfets can do nasty things on the edges as they go into and out off cut off.
Ian
Drewaudio,
Ian
you can make changes in the bias pot circuit/resistors so that those pots are not fully wound...
Thanks Ian. I will try and modify this current source to be a double transistor type instead. Does it matter how much voltage there is across the current source?
As I see it it is most important that the current is correct?
Thanks for the information. I've ditched the 6F6's for the time being as I couldn't adjust for a low enough current through the tubes in order to stay within the dissipation limits. I know I could change some components to achieve a lower range for the bias pots but I just love 6V6's in the amp.
I've also tweaked the bias PSU and have -48v. I'm struggling to understand why the amp cannot go into ab2. Is it because the fets are fed by a CCS that means the 6V6's cannot draw very much current from the grids? Or am I just missing something?? 😕
Cheers
Andrew
Cheers
Andrew
Hylle,
If you have followed any of the schematics posted then the current source is a "double transistor" type, we engineer types call it a cascode bipolar current source. There is a minimum voltage requirement but the maximum voltage across the current source is limited only by the voltage rating of the transistors. I like to use 2N5551 which have a 160V limit.
Andrew,
I have not actually checked but I would expect that with the source follower drive it is going into Class AB2 operation. Ditto on the 6V6. I'm running some 1950 6V6G from the Sydney AWV factory( the ST "Coke Bottle" shape) in mine with Philips ECG 6SL7.
Away for work at the moment (in Cairns) so I'm missing the sound system.
Ian
Andrew,
Ian
Thanks for the comments. I'm still trying to get my head around why I cannot get into AB2 territory (not that I want to, I just want to understand...). The conclusion I have reached is that the CCS for the fet is limiting grid current in AB2 therefore the tube won't go very far into AB2. Have I got that right??
Please correct me if I'm way off track!!
I am another diyer wanting to build this Baby Huey amp. A bit lost among the various updates brought along this thread, could someone direct me towards the final version aka the best sounding version?
- Does the wiki page written by Bas Horneman represents the final version?
- The speakers I want this amp to drive are Fostex Fe207, any experience with those?
- I'd be interested in a mono bloc schematic if it exists.
- Is there an existing list of components? I am staying in France and would like to order the lot to get started soon. (my SS Onkyo amp is dying)
Thank you very much for help and congratulations to those who built very nice unique amplifiers!
- Tubes / Valves
- EL84 Amp - Baby Huey
