Linkwitz Orions beaten by Behringer.... what!!?
Earl,
Sorry I didn't catch the scale on your plot you showed. Thought I was looking at 50hz when it was 500. When you say that all 15" speakers have the dip from the surround is that only with an M-roll surround or do you see the same dip with a 1/2 round surround also?
Pano, good that you did this test. I have followed the discussion about the claim that frequencies below 700 Hz are not an important source of localization with a mix of amazement and entertainment. Your test should refute it to the dustbin.
Let's look at the physics of the situation. A 700 Hz tone is just under half a meter long, the distance between a typical set of ears about 22 cm. It is easy to see how a sound source that is even slightly off axis will produce significant phase shifts in the sound entering both ears.
There is also a subtlety to the >700 Hz claim. Does it also mean that reflections from < 700 Hz are not detrimental to localization? Pano wasn't able to localize easily when the two bands were panned to different speakers.
A key aspect of reflections that is often misunderstood: is it correct to assume that a reflection of a 500 Hz wave is heard as 500 Hz? Not likely. Here's a post by speaker dave that speaks about it:
http://www.diyaudio.com/forums/mult...-covers-common-discussions-2.html#post2759273
He says, "We talk about reflections as if they are heard in issolation and have a particular frequency spectrum that is important. The reality is they combine in a particular way with the direct response based on their delay (and perceived based on direction and the ears inherent time windowing). So a flat spectrum reflection will combine with the direct sound for a very comb filtered response. The major deviation is around the first or second comb filter nulls. I have listening simulations and there are always major pitch effect determined by the particular delay. Flat plus flat does not equal flat.
At higher frequencies the comb filtering is dense, within a critical bandwidth, and the reflections add brightness."
Given all these points, how can we disregard reflections of (or directivity for) sounds < 700 Hz?
I am not a fan or "quick and dirty" tests as there is too much that can go wrong.
Yes, quite right. I hope to do further tests and have some other people double check them. It's easy to make mistakes.
FWIW, we did make some mistakes in the test, E.G, I could not hear the bass moving when panned L-R. We then discovered that it was routed wrong on the console and was not panning at all. No wonder it didn't seem to move. 🙁
I'll repeat the test as time allows and with input from the forum welcome. I'm tempted to try moving the image via delay, as well as via amplitude.
Pano,
I had hoped that you would make your experiment along the claims of David Griesinger. Two examples regarding the 700 Hz "threshold":
Experiments by the author and with students from several universities discovered that the ability to localize sound in the presence of reverberation increased dramatically at frequencies above 700Hz. Localization in a hall is almost exclusively perceived through harmonics of tones, not through the fundamentals.
The author believes that engagement, near/far, pitch perception, timbre perception, direction detection, and stream formation all derive from the same property of sound: the phase coherence of harmonics in the vocal formant range, ~630Hz to 4000Hz.
Bold highlights are from me to show why noise doesn't cut it as a proof.
Rudolf
...noise doesn't cut it as a proof.
Why? In what way? He does not say, as far as I can see, that the sounds have to be vocal for location. Just in the vocal formant range. I don't think many people have trouble locating non-vocal sounds. Do the sounds have to have harmonic coherence? Certainly noise does not.
Anyway, it will be interesting to try it with vocal and other musical sounds. Even with spoken word.
That sub looks from the pictures to have vents - might they have been generating duct noise?
You're welcome!
Basically the take away was:
  • Neither of us had any trouble locating full range noise. No real surprise.
  • Neither of us had trouble locating bandwidth limited noise all the way down to <50Hz when the upper ranges were not present. Not the conventional wisdom.
  • I was much better at locating bass <120Hz when the upper registers were present.
  • Widely differing bass and upper register locations were confusing to me.
Further testing will involve splitting noise and music signals at in half 700Hz and moving the two halves separately. I do not expect the top half to be difficult to locate. I don't know if the bottom half will be or not. A lower split point could also be used.
Markus, why are your posts always so derogatory and biased?
Seriously? I simply look at available data.
Show a better spot or better distance and better yet show some other speakers as well!! None of them are any good by your standards. You take the extreme worst and make it seem like it is the norm. I see why others get so frustrated with you. Your positions are seldom fair and balanced.
Keele's CBT looks very good. It's easy to absorb the side wall reflection if desired. They have high vertical directivity which eliminates the need for ceiling and floor absorption. Overall directivity is very well behaved. Not a "christmas tree" like most constant directivity designs.
Please look at the Griesinger sources that had been linked. All claims of Griesinger apply only to fundamentals with their harmonics. It is the essence of it all. Harmonics would not be harmonics if they were not strictly coherent with their fundamental tone. Noise is almost the complete opposite of this.
Rudolf
That's not the "physics of the situation". Greisinger posts ILD's and ITDs for the head somewhere on his site (no I don't have the link!). These functions get vanishing small below 700 Hz. Nothing at all compared to > 700 Hz. That IS the physics.
Rudolf
Rudolf - do you see the Greisinger papers as significant as I do? You certainly seem to understand them in the exact same way that I do.
Couple the Griesinger papers with the paper that you posted on resolution of amplitude modulations in the ear and one begins to see how potent the Greisinger hypothesis could be. The two papers together present a very convincing picture of some very difficult stuff to understand.
The other hand-waving going on here is not convincing at all. (Pano's results excluded, except that I agree that they need to be done with harmonic tones not noise.)
