The problem with a small room is the reflected sounds can build up very fast due to dimension and direct and reflected sounds are smushed together, and adding absorbtion to it doesn't really solve the problem - it just makes it sound dead.
Frankww,
Then are we just at the mercy of the room modes and that is all there is to it? Diffusion is not going to do anything for the buildup of those pressure waves just bounce them over a wider area, so what is wrong with some specific absorption in a room? In a small room it would seem even more acute than in a large room with a higher loss factor and greater distances from all radiation sources. With a normal 2x4 stud wall and drywall construction again is that really a high loss membrane at the sound levels we can produce in a small room?
Just working with unrelated pure tones I don't think would indicate anything either way. My experience, and probably also of Pano, indicates to me that the brain wants to understand the acoustic meaning of what it hears, and if the "message" is that of say a very large acoustic, reflections with significant delays, that is the "picture" the brain sees. However, harmonically unrelated sound with no echoes that match, correspond to the acoustic "size" of the main sounds will stand out as being different, very distinct, will attract your attention.Now what Frank is trying to say seems to be a different phenomena. I am not sure that we use distortion as a localization function so much as we will be aware of any frequencies that are not correlated to the fundamentals and harmonics of those fundamentals. We will clue into those sounds more because they just don't relate to the rest of the harmonic structure, if I am saying that with any clarity?
Frank if you would want to do that as a test I would say you would take a frequency and add perhaps the 2nd and 3rd harmonic frequency as a sine wave and just add in an unrelated frequency and do your test. I don't know what it would prove except that you would be aware of the uncorrelated harmonic frequency. How is this any different than somebody playing a guitar with one string that is out of tune? That is just something that you are instantly aware of, but I am not sure I would say that this would dominate any localization unless it was in the band where our hearing is the most acute or was at a higher spl level where it would instantly stand out?
A real life example is say a musical work being performed in a large church, and a kid sitting in front of you starts rubbing his shoes annoyingly on the floor. Your brain will "fly" to the source of that irritating element, your brain will localise that aspect in spite of the volume, and reverberations of the main sound.
Frank
Makes me wonder what they hell they're smoking - and can I get some? 😕When your results differ so markedly from other experts in the field it does make one wonder.
That is not all you ever said, but so what? You say "dominate source" or that <700Hz doesn't matter. Just how dominate? If we can localize a source below 700Hz, even far below, how can that not be important? Sure, if the source contains a lot of energy >700Hz, that might be what we mostly pick up on, but that about sources that do not? Do they not exist? Are they not important?Thats all fine, but irrelavent. The fact reamins that the dominate source of localization cues are > 700 Hz - thats all I have ever said.
That may be, but how do you have music and speech with no content below 700Hz? Just how do you test this? I'll have to read it over again.Griesinger does not speak about band limited noise, but music and speech afaik.
In my tests I tried to locate a tone that was panned back and forth between two speakers. I found pure tones very difficult to locate, no matter the frequency. When I used broadband noise or noise that was sharply filtered, it became easy. Below a certain filtered frequency - near 80Hz (IIRC) I couldn't follow the shifting sound any more.
I'd be happy to try the tests again with different speakers, for example Meyer Sound, and in a bigger space or perhaps outdoors. I don't doubt that midrange signals will be easier to locate than low frequency tones, but my experience has been that low tones are not all that difficult to locate.
Just to add to my previous post, if the reflections of the distortions in the listening room are significant then the brain will be in conflict: it's trying to decipher the recorded acoustic signature as well as the reflections of that, AND on top of that the reflections of the distortion. This is more than the brain can make sense of, and it gives up ...The problem with a small room is the reflected sounds can build up very fast due to dimension and direct and reflected sounds are smushed together, and adding absorbtion to it doesn't really solve the problem - it just makes it sound dead.
Frank
700Hz is a weird number... it sits nearly in the middle of the human vocal range.That's one area that I would expect directionality to be perfect from the full 100Hz to 1200Hz range. We have evolved to track down crying babies.
There is also a subtlety to the >700 Hz claim. Does it also mean that reflections from < 700 Hz are not detrimental to localization?
A key aspect of reflections that is often misunderstood: is it correct to assume that a reflection of a 500 Hz wave is heard as 500 Hz? Not likely. Here's a post by speaker dave that speaks about it:
http://www.diyaudio.com/forums/mult...-covers-common-discussions-2.html#post2759273
He says, "We talk about reflections as if they are heard in issolation and have a particular frequency spectrum that is important. The reality is they combine in a particular way with the direct response based on their delay (and perceived based on direction and the ears inherent time windowing). So a flat spectrum reflection will combine with the direct sound for a very comb filtered response. The major deviation is around the first or second comb filter nulls. I have listening simulations and there are always major pitch effect determined by the particular delay. Flat plus flat does not equal flat.
At higher frequencies the comb filtering is dense, within a critical bandwidth, and the reflections add brightness."
Given all these points, how can we disregard reflections of (or directivity for) sounds < 700 Hz?
+1Makes me wonder what they hell they're smoking - and can I get some? 😕
A simple test that anyone can do with even the most rudimentary DAW feeding their speakers . . . split a mono signal (anything will do, even Mozart) at 700 Hz., put the "above" in either (stereo) channel and pan the "below" back and forth, left and right.
Tell us whether you hear any difference.
I always wonder about this expression, why would you want to smoke something that makes you incorrect 😉 doesnt sound like a very euphoric/sublime experience 😀
Certainly if there are instruments that cover both sides of that range, you will hear constant shifting of image.
I would expect reflection to increase indirect sound path plus diffusion plus absorption to work best.
It's the speed of the build up of correlated HF reflections to a steady state which is too loud: they behave like noise. Subjectively, they mask the direct sound from the speakers including the recorded spaciousness cues. But too much absorption kills the modes necessary for reflection giving spaciousness and comfort. (Been there, got the T shirt - it doesn't take a lot of absorption. I also have a small back room full of books and music in there sounds really awful).
(LF can maybe sorted with multi subs and EQ since the problem with them is a scarcity of modes)
So, what's wrong with absorption on the wall behind and (maybe) beside the speakers, using directional speakers to avoid too early reflections, keeping the rest of the room live, using some diffusion in the live portion to give more decorrelated reflections. AND (gasp!) using delayed and rolled off helper surrounds to make the room subjectively larger? My thinking with this latter is that done right it ought to make the D/R ratio better, subjectively.
Frankww,
My room is 14 ft. by 23 ft. The speakers are three ft. out of the corners (both walls) and toed in at 45 degrees. I don't think that a drawing would make it any clearer. There is nothing in the front of the room forward of the listening seats except the speakers (subs in corners behind the mains).
Thanks but where's the main listening position?
No, you've said that <700Hz is unimportant. That's something entirely different.
I agree that >700Hz is dominant but this is not the same as saying <700Hz is unimportant. You might have never heard it because of the amount of LF dampening in your room. But most people listen in rooms that don't have good LF dampening. So you're talking about a special case that might not be very relevant to most of us.
I don't use nor do I believe in bass traps. They are not effective enough - my whole room walls are dampers - LF only. The corners are better places for subs.
I know that most rooms aren't built like mine - but they could be. What would I do in a normal room? Maybe rebuild it. Its easier than most people think. But band-aids to a common disastrous room? I don't have much experience with that. I don't do band-aids.
well, this is what 4 limp mass corner traps do:
http://imageshack.us/photo/my-images/221/timlimpmass.jpg/
not too shabby hey? 🙂
700Hz is a weird number... .
well, maybe it is a very good and convenient number when you build speakers. 😉
just a compromise, maybe?
lolo, can't read the labels. Got a description/pictures of those absorbers?
Edit: Found the thread - http://www.gearslutz.com/board/8062579-post57.html
I would think the proper test would be to create a signal with a fundamental at say 200 Hz and maybe 10 harmonics. Then delete the 200 and 400 Hz ones and see if the localization degrades. That's really the test that proves or disproves the claims, not that one can or cannot localize some signal below 700 Hz, only that below 700 Hz adds almost nothing to your localization ability. It is dominated by > 700 Hz. Thats the claim.
are we talking transients?
two examples. listen to Mahler's n.1 opening with Paul Magi. What the conductor achieved is a window in a trully new mental space. Can you localize the sounds?
next. 2L "Divertimenti", track 2. Can you now localize precisely every instrument despite the reverb?
Markus, here is the link for these traps:
http://www.gearslutz.com/board/bass...etc/743040-tims-limp-mass-bass-absorbers.html
Don't I remember Earl saying that he has three feet of foam stacked from floor to ceiling in his room against the front wall? Wouldn't we consider that in itself a room absorber that would reduce front wall reflections and act as a bass trap of sort for the entire room?
- Linkwitz Orions beaten by Behringer.... what!!?
