99.9% of audiophiles all over the world do not understand noise, do not understand FFT and confuse noise with noise spectral density (FFT bottom).
Here's another example - I don't know if Andreas Koch calls himself an audiophile, but you might be forgiven for thinking he knew better than to draw the noise floor line for 24bit PCM where he's put it in this graphic : http://www.playbackdesigns.com/wp-content/uploads/2012/11/Picture4.png
<edit> by the way PMA, the factor is 10 in your log expression as we're dealing with powers, not voltages 😉 You must've used 10 yourself to get the result to be 45dB. Ooops, no sorry you're right - missed out the sqrt - easier to write it and calculate it as 10 log (24000/0.73).
Oh no, for it is AMPLITUDE SPECTRUM (see the image properly)
For amplitude spectrum, we have 20 log V1/V2
For power spectrum, we have 10 log P1/P2 and get the same dB. There are only one dB's in this world 😀
Please do not argue, I have the FFT measurements verified.
My first experience as a child of about 5 or 6 was having my grandfather or uncles hand me what they thought were broken pocket watches to play with.
My dad gave me a totally disassembled 1964 VW bug engine in a box...I was 12. Best erector set ever!!
Afair, Mr Harrison used Guaiacum wood for the bearings of his clocks.
He did some really amazing things.
What I don't understand is WHY precise measurement of power supply frequencies is of much value? What I find more important is WHY some power supplies are sensitive to line cords and some are not.
Ground loop. Total lack of control over current paths and Faraday's law of induction.
you are not kidding. I machined up some coco bollo, and got the
dust all over me. Was red and itchy for more than a week.
At least I was smart enough to wear a face mask. Inhaling that
has got to be real bad.
I thought I was living on the edge with purpleheart..😕
Ripple is more of a linear slope due to the almost constant current draw. Do C dv/dt = I works well for the discharge drop. The charging time gets more interesting due to the rise in transformer output voltage as the capacitor charges.
ES
I'm far more interested in how mutual coupling affects input to output of each filter cap.
jn
Now, let us get back to looking at distortion differences in op amps. Please note the distortion waveforms on the left:
MY estimate of an IC's 'audio quality' is related to the steepness of the distortion waveform. If it looks like 'Switzerland' you are in trouble. If it looks like 'rolling hills' then it is probably good sounding.
Personally, I don't care if this non-linearity has to be measured with 'heroic' methods. In my personal opinion, you don't have to measure significant distortion that is probably buried in noise or is very small, because the intrinsic non-linearity of the transfer function appears to be the key, as this non-linearity may appear to the ear as a different (non-measured) distortion such as PIM, but that is only one distortion that we know can be generated from the intrinsic non-linearity of the device (without feedback covering it up).
