F6 Amplifier
@flo
1u is way too much
been there , erred almost the same :rofl:
Where is the rest of the table😀 and what was the calculation. Way too busy and lazy to look for myself. Are we talking snubbbers here, or just bypass caps? I have heard some folks dont like snubbers, whats your opinion. Gotta go finish tapping sinks. I hate tapping, even with drill.
buzzforb. This is a suggested procedure. Your pcb shows that power to both amps is applied simultaneously.
  • Separate the turn-on of the amps
  • Cut with razor the +Vc and -Vc traces to left channel. Ideally, each channel may have had its +/-Vc lines independent from the other.
  • Ground the bridge resistor; the one [low value] connected to the primary winding of the Left Amp. Is this 18 Ohms? I only see one resistor bridging R and L amps.
  • Bias this R amp l like you've done with diyF6 .
  • Disable power to the R amp [razor cut the traces].
  • Lift the feedback resistor off ground.Connect its other side to ground.
  • Repeat the above for the L amp tyo bias the left amp.
  • Disable power.
  • Lift the bridge resistor off ground.
  • Now you are ready to apply power to both amps.
  • Disable power.
buzzforb. Here is a much simpler procedure [than above] to start up.
  • Cut with razor blade the traces emanating from the outputs to the 100 Ohm feedback resistor of each amp.
  • Thus, both amps are no longer bridged, and each operates open loop, and independently for biasing..
  • Apply power. Adjust the bias and stabilize the operating point of each amp like in diyF6 [one hour].
  • Preheat the soldering iron
  • Turn power off to the balanced diy amp
  • Give yourself one minute to solder the traces that you cut.
  • Power up.
If the above is not done, there is the probability that the series connected feedback resistors can see ~45 V, and thus overheat.
Best regards.
You are welcome. Hate to see inadvertent problems in your work. The simpler procedure above is also useful to start up a solo diy F6. First there is no reason to subject the feedback resistors to a +/- output voltage, and more importantly to push a Direct Current through the primary; a no no per Jensen
Can't say I understand this. The offside transformer will not be connected to ground. How can dc flow through it. The series feedback resistor will function as it normally would in standard F6.
I am proposing that a current will flow through the primary winding from the grounded feedback resistor [ say 1 VDC ], then through the sources of the FE JFETs and out of the drain of the p-channel JFET [grounded common gates] so as to absorb their new current imbalance.
I am surprised that you connected Zen pots. Your bridge amp is expected to have lower distortion [due to distortion cancellation] than either of its solo diyF6s which already have low distortion before and after loop feedback. Afterall, are'nt you aiming at a vanishing distortion with your bridging setup; maybe in the range of 0.001% -0.0001% THD. Maybe the pots are for bias. In this case please strike off my comment.
Antoinel
when we are going to see your homework ?
( just ignore fact that nobody can see mine , that's the way the things are )
:rofl:
Zen Mod. Homework is a bitter pill, and is fortunately therapeutic. I already have four R100As, and their PCBs from Tea-Bag. I am also waiting for a diyF6 kit [parts inclusive backup output MOSFETs] from buzzforb's past GB; forthcoming in a month. PSU is forthcoming also.
I have other 'skunkworks' projects on semi-standby, as I simultaneously attend to this thread.
