Smps with IR2153 for audio amplifier
My design an switching power supply use IR2153 + mofet(or IBGT) for audio amplifier
+/-63V,12A (unregular)
+/-15V,800mA for pre amplifier circuit
+12V,800mA for protect circuit,fan,...
size 12x12cm
Testing with load is resistor 30ohm(4.2A) + 1 lamp(0.6A) = 4.8A from B+ to B- ( total 126V = 63Vx2)
P = 126x4.8A = 604W not use fan in 2h
Heatsink for mosfet about 95 oC,if use small fan is power higher
Hi Hien.t.nguyen
greetings is this full schematic
1 source of CPR signal
2 overcurrent protection
3 voltage feedback
warm regards
andrew lebon
Dear Andrewlebon
1. Point CPR is over current protect (about 20A at pri)
3. My smps use IR2153 unregular for main voltage(+/-100V),not need voltage feedback
My smps has been over voltage protect,over current protect,over temperature protect.
regards
Hi Andrewlebon
If you want to perfect protect,you can use this schematic
It is protect speaker and power amplifier,DC at output amplifier will be checked and if has incident(DC<>0.7V),power will not operation.
