Another hoax
Hello
Look at the image, Neosocket, that's quite a hoax !!!
A guy did open it and there's only a diode into that device.
Bye
Gaetan
Of course, car manufacturers have never heard of capacitors and, at least in Europe, are under great pressure from governments to increase fuel usage so would not use this technology. Once again, the small gadget makers are helping the common man fight back against big business, which seems to insist on building cars without capacitors and audio amps with capacitors!
It makes no sense,even if the capacitor is a flux capacitor holding a couple farads,when the electric sistem is not under load the capacitor will pull power and consume more gas,as long as the cap dosent produce power on its own i dosent help at all
