Anyone who bought one of those should have his driving licence revoked, on the grounds that he is obviously too stupid to be allowed on public roads.
A bit more than a diode, but not much more!
There will always be a diyer around here willing to mod it with Backgates, Caddock and Hexfrets.
http://www.compendiumarcana.com/fuel_doctor_fd47/NeoSocket.jpg
Apparently the capacitor holds charge and releases it when heavy loads require it, relieving the alternator of some of it's load
Neo Socket Review - Best Fuel Saver
Tony.
Tony.
Of course, car manufacturers have never heard of capacitors and, at least in Europe, are under great pressure from governments to increase fuel usage so would not use this technology. Once again, the small gadget makers are helping the common man fight back against big business, which seems to insist on building cars without capacitors and audio amps with capacitors!
It will increase the efficiency of your Class D amplifier to about 115%. Your electricity meter will run backwards whenever you listen to music.
Wow! I need three!
If I ran my hand cranked Victrola into an amp connected to a few of these, it could power the whole house.
Wow! I need three!
LOL! 😀
Hello
Just beat Neosocket and use this capacitor... your car will run faster 😉
Car Audio Capacitors 2 Or More Farad High Watt Coverage Amp Amplifier Authorized Internet Dealer
Bye
Gaetan
Bye
Gaetan
Hello
A guy did open it and there's only a diode into that device.
Gaetan
Well that will rectify the problem !
It makes no sense,even if the capacitor is a flux capacitor holding a couple farads,when the electric sistem is not under load the capacitor will pull power and consume more gas,as long as the cap dosent produce power on its own i dosent help at all
- Member Areas
- The Lounge
- Another hoax
