Class D Amp with LM566, LM393 and 2XIRF530
I want to supplied my amp about 2*40v.
So with 2*30v transfo it's ok (30*1.414=42.5v)(42.5-2.4=40v) 2.4 is the loss in the diode bridge.
But I have a problem to select the power of the transfo !
I think 200W it's ok because the amp can "give" 100W+ the heat loss (30w)+the loss in transfo(40w)=170w (30w of margin).
What do you think ?
What do you think ?
Heat loss must be under 10W, but 200W is ok.
try using IRFP240 to compare with IRF640 with same voltage and coil 51 turns. BTW can BAT 86 instead BAT 85, sir ?
