What is the safe voltage for B500 with 3 pairs of transistors?
It will be used only for 8ohms load.
I need about 250-300W.
After all im going to build this amp,this is a little more complex but i think its ok,\
I need pcb pdf so when i print it its the correct size
So the power to 5532 is more stable and it will sound better,also we will be able to get more power by increasing the voltage past the 90v mark and adding more outputsThis CCS circuit add to B500 instead resistors feed zeners with 30mA with any rail voltage.
Power to NE5532 (+/-15V) will be stable from +/-30V to +/-90V rail voltage without any changes.
And what voltage and current transformer will i need for 1 chanell(im going to use one trafo per chanell)
Im going to rewind microwave transformers since theire cheap
hi Apex, I have made TEF B500 and have been successful, but there are a few questions:
1. predriver transistor (MJE 350/340) and driver (5200/1943) is rather hot, is this normal?
2. how much minimum voltage for B500 TEF?
Thank you,
Thank you,
Put a heatsink on them,on both since 52001943 snd the 340 350 anre hard at work since they have to drive a lothi Apex, I have made TEF B500 and have been successful, but there are a few questions:
Thank you,
Thank you,
This is normal and you must use heatsinks for drivers and predrivers.
I printed it and it came out perfect in size and everithing lines up bu how do i transfer it to the pcb since i only have and inkjet printer
What is the right transformer for 1 channel Everithing else i sorted even the printing
thanks for the response.This is normal and you must use heatsinks for drivers and predrivers.
how about minimum voltage for the B500 TEF?
regard,
You can use the machine / copy services, it's the same with laser jet printers,🙂I printed it and it came out perfect in size and everithing lines up bu how do i transfer it to the pcb since i only have and inkjet printer
regard,
oook that exactly what ill do when i get ink for my printerYou can use the machine / copy services, it's the same with laser jet printers,🙂
regard,
i found on the romanian sits an amplifier called ipa800 which is very famous and i heard its very simple but i didint find pcb and layout for it.
Has anybody from here heard about it if yes please send me pcb
- 500W PA amplifier with Limiter
