Sony SS-AR2 Top and Bottom Bracing
Looking at the attached photo of the Sony SS-AR2, you'll notice that there are wood braces at the top and bottom of the cabinet.
Are these braces useful, either theoretically or in practice?
Thanks all.
Thanks all.
I would go further. Your cabinet can't be too stiff. Here is what I did. Notice the last shelf brace is itself braced against the end panels. Don't use mdf for bracing. 1" ply is much stiffer after cut-outs.
Have to be shy as this is a hush-hush project and I've been sworn to secrecy.
Using 19mm and 30mm BB ply. BTW those braces are a work of art.
In my quest for stiffness (sounds like an adolescent dream), I'm worried about too many braces causing a significant reduction in volume.
Cheers.
A further thought; these Sony speakers are $25,000.
Knowing the attention to detail that went into the design and manufacture of these speakers, and the extensive bracing inside, surely the designers would have to have a compelling reason to include the top and bottom braces? And wouldn't they have oriented them the way Planet 10 suggested?
