Congratulations all pics seems originals😉
I'm grateful for the education here. Even with all the differences pointed out by valve, you believe they are all originals?
Have you ever seen a BG you didn't believe was original?
I've seen very poor copies of caps that are obvious to anyone, but most good copies I've seen are indistinguishable externally. That's why I'm amazed you're able to determine they are in fact originals.
You my friend, possess powers far beyond my own.
I think analog_sa summed it up when he pointed out that the only sure way of finding out if they're genuine or not is to listen to them or cut them up.
merlin el mago, I'll let you know when I'm selling!!!! 😀
I agree....and good plan. 😀
You must read between lines, my afirmation is only looks originals. I doubt you have had and ear at some time a black gate😀
anyone know the ESR impedance of these caps ?
Some info here:
http://www.octave-electronics.com/Parts/cap/bg_tech.shtml
http://www.partsconnexion.com/t/resources/blackgate/blackgate113.pdf
http://www.audiotuning.de/english/index.html?2-01-blackgate-tech.html
http://www.partsconnexion.com/t/resources/blackgate/blackgate051a.pdf
Different case size for same value, 220uf 100v standard? Anybody else found this? Seems a little suspect to me!
different can size for the same type, and value ?.. yes, that does seem weird, and suspect
..... so are the Tufnol ones genuine?
I have 220uf/100V with tufnol ends
Not sure if this info is of use to anyone but if people can have a look at their own stock, which they know to be genuine, then maybe it will help in a small way to identifying any possible fakes out there!
dont know about the cap type letter
I only have standard type, and none them are marked with type letter
but all the more expencive special types seem to be
and on that point a few of them might need a closer study
Some info here:
[/URL]
appears they claim to have smaller can size than usual
maybe it all really does come from the early and first efforts to devellop smaller lytic caps
looks more like proto type documentation
reminds me now
some years back there was a debate about how to build a fast burn in rig especially for BG caps
because BG caps had a bad reputation for sounding harsh when new
and one known reason for this was 'inadquate function'
I found it all highly dubious, and one reason why mine have now become NOS
which now also makes me wonder...does anyone know how old they really are ?
are there any spec sheets with date codes etc ?
Silmic and other NOS lytic caps ? could be they are still ok.... but I say, no thank you, I want them fresh
actually, I might even consider all 85degr caps to be 'outdated', and near the end of their 'shelf-life'
you might find many 85degr caps 'on sale'
My Blackgates , all originals - from appointed dealer . Note the words are very "gold" & crisp , I am told the faked ones are with less "gold" & blurred lettering - one point that faked goods manufacturers do not want to invest too much money in . This also applies to other faked goods from China ,
please take it as a rough guideline if you are not 100% sure of it is genuine .
Larry
Larry
reminds me now
So far I've not been able to dig up any info on date codes and the BG's I have look like they may have month codes not year codes. Therefore not really any way of telling how old they are. There must be a point at which BG's, or indeed any other cap, start to degrade beyond recovery and who knows what that time span could be. Better check my Silmics!! As you say, there are plenty of reputable manufacturers out there to try and, considering the difference in costs between them and BG's now, I'm sure the difference in performance would not be that great.
Larry
All indications (other than the tolerance of the 100uf FK's) seem to point to the fact that mine are genuine and the print seems to be similar to yours. I'll make a decision on the 100uf's when I've tried reforming them. From a personal point of view, I wouldn't even consider buying any supposedly genuine BG's at the price they are now as it doesn't take a scientist to work out that, as their rarity and value increase, so does the chance of getting fakes. I'll probably sell my 330uf NP's and just use the others when the need arises. Any new caps I do need, I'll get new stock.
Dean
Which type/values do you need to know? I still have many and can measure them with the bridge at 100Hz/1kHz.
hi, I was just interested to hear if anyone knew
I seem to remember low ESR mentioned
but I dont remember any values
are there any ?.... that's what I asked 😕
but thanks anyway 🙂
Type / Value / Voltage / Z, ohms@100Hz / Z, ohms@1kHz
FK 100/25 - 0.2 / 0.08
FK 220/25 - 0.16 / 0.038
FK 470/16 - 0.07 / 0.028
STD 220/16 - 0.41 / 0.137
NX 100/6.3 - 1.1 / 0.40
NX 220/6.3 - 0.39 /0.179
PK 100/10 - 1.0 / 0.51
Can't find a lot of info on Blackgate factory tolerances but here's a start;
Std, N, NX +/- 20% (info re N and NX comes off EBay so take that as you will)
AC Speaker +/- 10%
Can anyone supply definitive info?
AC Speaker +/- 10%
Good info, thanks to share🙂
I have using these caps from time to time and since some of them are used ones , removed from my own gears that I no longer used , I used to take measurement to see if it did stay in shape and hold a charge without quickly dis-charging it , from all my past experiences , these caps were always closed to within 5% tolerance before any re-forming . Some of my caps are over 10 years old , some maybe 15 years , but most of them were used in mild conditions , never too hot , thus , they remain in good shape .
The word length of Rubycon is @90% the length of Blackgate . Not exactly the same . Space or no space between , both are originals .
Larry
Reforming the 100uf 100v FK's made negligible difference to value. Also very little leakage with them so I guess, as suggested, they are originals but just towards the bottom end of the +/- 20% tolerance.
- Design & Build
- Parts
- Fake Blackgates??
