Foam Core Board Speaker Enclosures?
I forgot to mention that I also double up on the glue by liberally applying white, or in your case, yellow glue on top of the hot melt just in case there are any cracks that need to be sealed, plus it ensures that if hot melt ever gives you have a backup bond.
Solid idea. When I build a conventional cabinet, despite a [apparently] air-tight joint, I always seal the inside of the joint with white glue or sealant.
Speaking of which, might silicone sealant work faster, better rather than white/yellow/green/blue/pink 😀 glue?
Silicone certainly works to seal, smells bad though during drying. I now use hot melt to seal joints that I have access to and use my fingernail to tool it smooth to a fillet. I sharpen my xacto on a ceramic now before each build. Important to have sharp razor.
Are you building anything Kmossman? Welcome aboard!
Details of Flatter is Better BIB build in the Terry Cain BIB thread. I thought since it is a foam core build, better to post final pix and sound clip here though.
They sound great and have the ability to fill the room with some nice bass. I like how they ended up looking too. I just need to decorate them now.
What do you think of it versus your Cornu derivative?
1) spot 'weld' using the hot glue
You will find your happy place once you do one. Trust me it won't be the only one but it will help you find your comfort level.
2) seal and hold using [silicone] sealant
[silicone] I am hoping this is a generic term for the many caulks you have the option of using. Silicone base is the last one I would use. The one the seems best suited to this application has to be the cheapest one you can buy. Available everywhere. I spend funny money on a lot of things but as a caulk this one is very successful.
Alex® Painter's Acrylic Latex Caulk | Canadian Tire
yep! use in a well-ventilated area
you use your fingernail to 'push' and smooth the hot glue!
shades of Lawrence of Arabia!
maybe I am not 'green' but I use a box cutter aka utility knife
just snap for a fresh, sharp blade
I am really interested in this thread as building conventional [speaker] cabinets is impossible for me at present.
My last speaker project [many years ago] was the tri-amped LH transmission line speakers using KEFs [damn tweeters kept blowing so replaced them with .............damn forgot!] They were fantastic until some freaking brat poked the woofers all over with a sharp pencil !
Am building a test power supply especially for my projects....nothing exciting there.
A modest switch box with a simple op-amp booster for use with my desktop speaker system
And some potentially commercial e-bike projects! sadly, all are non-audio - although I am [just for me] installing a WICKED set of sirens on my e-bike to act as an auxiliary horn.
AS WELL [!] a commercial venture [can I say that?] with a local guy here in Suzhou, China. He has been hand-crafting valve amps for 15 years. I am one picky SOB on electronics - I NEVER saw commercial work that I could not fault - until I saw his work. This will show him and some of his work Flickr: KJ_Electronics' Photostream
Welcome aboard!
Thank you!
Squeak,
I had to pull the drivers from the Cornu's to put in the FIB's so I have not been able to do a true A/B comparo. But, my impression is that the BIB's have lower bass extension than the 20 in Cornu's, however they do not sound as "expansive" as the Cornu's. I think for certain music where a harder driving bass sound is needed, the FIB's are better, but for most music, the Cornu's sound better, especially jazz or anything with horns or woodwinds. I may pull the drivers from my cardboard MLTL's and put them in the Cornu's so that I can do a true A/B test and update this response. One thing that I have found with the FIB is that it is very sensitive to stuffing, I had to play with it quite a bit to get the sound I wanted. Maybe I just got lucky with how I did the stuffing on the Cornu's because it was good the first time.
ops! yep, you are right. I got stuck in the silicone rut. I usually buy the silicone stuff [here, in China] because:
- it's available
- can use it for 'anything', 'anywhere'
- i know it works
I do MISS Canadian Tire, Home Depot, ....................
China is a DIY desert !
Maybe try this:
2) seal and hold using [silicone] sealant [the sticky stuff that dries and bonds]
I think the point of that post was to see if one could build a Cornu using nothing but hot melt glue. I was impatient and wanted to have an instant Cornu without waiting more than 20 seconds for the hot melt glue to harden. The first Cornu I built I indeed used the hot melt glue to tack, and then used PVA to seal and glue as I was down to my last 5 sticks of hot glue! The final capping off procedure of gluing the face was always the slowest as it required waiting for the PVA to dry over 6 hours.
If you are abroad, this style of DIY is perfect as it can be done in a hotel desk with a knife and hot melt glue gun.
I sharpen my xacto razor mainly because it is one of those fine point triangular tips that I like for precise control and I am too lazy to go buy more. It actually works quite well to sharpen rather than discard each time.
Finally, here's a photo of my 20" Vifa TC9FD masonite/foam hybrid with banana leaf paper. My third foamcore build. I still need to get a photo of the birch ply pair that I built for a friend. He's re-discovering his music collection. Still amazed at how good these can sound.
Now I need to order some more drivers and decide what to build next! 🙂
One curve done, one more to go...
Using a 40W glue gun, one thing I've learn, is to keep using it, else to switch it off after more than 5min of idling to let the glue cool down to stop it from melting the foam.
Very nice, I like the banana paper look! You and Prezden have nicely decorated speakers. Glad you friend loves the sound. I am still amazed at wht these little Vifa's can do everytime I turn them on and listen. 🙂
If you are looking for the next project, may I suggest this?
