I cannot get the flip flop (74AUP1G79GV) in GV package. What else will fit ?
Choices at Element14 (Farnell)
Formerly Farnell | Electronic Components Distributor | e絡盟 Hong Kong
Nothing at RS ?
Buy 74AUP1 online from RS Components
Nothing at RS ?
BOM
AKL-AMN-SXX BOM - View/Edit/Update
Added:
U3, U4, U5, U6 568-5393-1-ND 74AUP1G79GV 1CH FF 4 $0.49 $1.96 DIGIKEY Alternatives:SN74LVC1G79DBVT(Farnell:1741129)
Do you have a xls version of the BOM?
Added:
Added:
Thanks - so it's a dbv package - SN74AUP1G79DBVR would be better. I can't buy it but I can get samples with a ton of wasteful packaging. This industry is mad.
Thanks for your help !
Acko, do you have part number for the U.FL cable assy ?
This is for a 100mm 0.81m cable assembly you can use the Mfr part number to search other sites
Mouser #: 530-415-0085-100Mfr. #: 415-0085-100
Added:
Excellent thank you
Gents,
I am considering doing a small GB for say 10 - 20 of us who are getting these PCBs. Since small orders from DK to non-USA customers can be expensive after including shipping fees.
I will post back here tomorrow details of my offer, likely won't be a huge discount on DK part cost but should be a small saving and certainly cheaper than ordering from RS/Farnell. I need to consider keeping the GB small to avoid import duty charges into Aus or we'll likely lose any gains that we might have made. Please don't start lists or anything for it yet, if we do this I'll start a separate thread to avoid polluting the PCB thread.
Chris
Chris
Acko,
A minor typo in the BOM I think. C5, C6, C7, C8, C23, C24 - you have listed qty of 9, should be qty of 6.
Not a big drama but just thought I should point it out.
Chris
Chris
BOM Updates
Thanks, BOM updated to reflect these: AKL-AMN-SXX BOM - View/Edit/Update
Please feel free to make changes to suit other options.
Also, if anyone could volunteer to split the BOM for the S01 and S02 versions that would be great!
SN74AUP1G79DBVR would be better. ......
Acko,
I had done exactly that in Excel last night, just copy/pasted it in to the Google Docs spreadsheet 🙂
Chris
BOM
Before you order all the parts as indicated on the BOM, please note that there a two versions of the re-clocker on one pcb panel. S01 uses conventional Flip-flops and S02 uses PotChips. So if you are just after one type then get the parts accordingly for some savings.
Also, depending on how you wish to use the boards there are again further options:
1. For instance if you only need the isolation function then there is no need to load the FFs and related parts. Just wire out the outputs from the isolator of the AKL unit to the DAC or device. On the S01 board there are pin pads marked "Data" "LRCK" etc just before the FFs to make this easier. e.g. if you are using Ian's FIFO-Reclocker and want to provide some form of isolation before the I2S signals go into the 'BackDoor' unit of the FIFO module. Or, if you feel that somehow the ESS DACs will eliminate or sufficiently reduce any jitter from the isolator that makes it pointless for any external re-clocker?
2. If your transport or device already has isolators e.g EX2UI, WaveIO then there is no need to populate the isolator section of the AKL units. Just wire in straight from the transport signals to the FFs of the AKL units. Again, on the S01 board there are pin pads marked "Data" "LRCK" etc just before the FFs for this purpose.
BOM- more options
The LDOs on-board and related parts are also not needed if you have an external 3.3V source from DAC side, etc. Not much savings here but less labour pains soldering these tiny parts! Connect external 3.3V supply to the headers marked.
But note that there is fair amount of switching going on at re-clocker section so it best not to share DAC supplies if possible.
Can we summarize now, what will be best option to build for Amanero + Buffalo IIISE?
S01 or S02?
Re-clocking or not?
Do I need iL711 (U2,U8) or not?
ADP150 LDO 3.3V or external 3.3V from Amanero (external Salas BiB 3.3V power supply)?
Thanks!
S01 or S02?
Re-clocking or not?
Thanks!
Gents,
Chris
I'm in when you are ready, no hurry for me.
S01 or S02?
Re-clocking or not?
Thanks!
Is hard to know with 100% certainty.
If it was me with that setup I would build S02 with reclocking. And S01 with just isol. Then compare. If you don't have any external controller you won't need U2 or U8, unless you use amanero DSD enable or mute signals already then you aren't going to have anything to connect them to.
Chris
Is there a error in BOM for ferrite FB1,FB2,FB3?
Ferrite FB1 (1206) should be only in S01 ans FB2 ans FB3 (0603) in S02
Yes, you are correct. I added those columns and that was my mistake. I've fixed it now though 🙂
Chris
hochopeper said:Is hard to know with 100% certainty.
yeah, thats kinda why they are both on there....
- Group Buys
- Amanero Isolator/Reclocker GB
