Hi All,
I'm not at all new to electronics DIY and I have some experience with very basic woodworking and access to appropriate tools. That said, the last time I tried to build a speaker cabinet it was in the 9th grade with mitered joints and cleats and, well, let's just say that I didn't get very far.
Ok, that out of the way, being all grown up (outside) and motivated, I've decided that the MTH30 seems like it will be a good companion to my alto TS110s and I want to shake this fear of cabinet building as I have some other projects where ultra-budget is essential.
So, if you guys don't mind, I have some really basic noob questions.
1) I see that the MTH30 calls for MDF. I would rather use plywood for weight, is this a good idea? If so, does it require changing the plan in any substantial way? Any experiences with plywood vs mdf would be helpful here. I don't care about the additional cost if it makes the cabinet lighter.
2) Are the cabinets glued and screwed, or just glued, I can't tell from photos online. They appear to be just glued.
3) From the pictures that I've seen, I'm not seeing anyone line the cabinets with the acoustic dampening material that was found in virtually every speaker made when I was a kid. Do you not need/want this in these type of cabinets? Don't laugh, I really don't know the answer.
4) I'm in the U.S. so getting one of the called for drivers is a bit expensive. I've seen that people have used at least two different alternative drivers that are available from parts express. The RCF LF12g301 and the Goldwood GW-12090. The RCF is $199 and the Goldwood is $99. I also have a couple of JBL tops with 2206s in them that I could borrow temporarily to try out and compare. The question is, what differences should I expect between these drivers? I'm really new to this so I don't yet have any intuition on translating driver specs to real world differences. So, if possible, please be specific and discuss in terms of real world performance differences. I'm not adverse to buying the right driver, but I don't want to waste money on differences that I can't use. I care a lot about sound quality, I care a little less about maximum output.
If it helps this (or these if I build two) are only going to be used for DJ applications, both indoors and out, for small gigs. I largely play somewhat downtempo as well as classic house music, if this helps understand my application. Also, you can assume that they will be powered with an appropriate amp for the driver, so that isn't a factor in which one that I choose.
Thanks in advance,
gs
Thanks in advance,
gs
