Gootee, let me try and make it more obvious that I am agreeing with you. A snubber has two critical parts right? A cap and a resistor? If either value is wrong the snubber ceases to perform its purpose. My cap is too small to snub the 14KHz resonance. After all caps DO snub. The difference is between snubbing and damping. It's a snubber and not a damper because it only damps resonances above the corner frequency. The cap's effect is to prevent damping frequencies that do not need damping, so that power is not wasted or linearity not compromised.
My damping resistor needs to be lower than 16R. How can I put this directly across the secondary without making a smelly heater or ozone destroyer?
BTW, thanks for the math info. I did not know that trick.
