LM1876 arduino mute
hey guys
i am waiting for my arduino MEGA to arrive in a few days.
i need to switch a bunch of LM1876's op amps on/off. they have mute pins that mute the signals passing through by receiving 2.5v.
so i figured i could use the arduino pins to switch an array of amps on/off.
however, my question is - do i need to put some kind of resistors inbetween or something to avoid drawing too much power/frying my arduino while muting 10+ LM1876's??
i should add, by default ALL AMPS WOULD BE MUTED AT THE SAME TIME - meaning id continuously be sending 5v through at least 10+ pins most of the time.
also, another question - i have never tried the LM1876's mute function - its instantaneous, right? im building a musical instrument, so if the mute function is delayed, its useless.
thanks!
has anybody seen a schematic where the mute function is applied?
i cannot for the life of me get the damn thing to mute the signals! with a split power supply, its just 5v to pin 6 and ground, right?
thanks for all your help guys,
ú
yes, i know. i have actually been obsessively reading the datasheet for a week now. thanks though!
i think i might go for optocouplers switching the input signal on/off before the amp circuit. this just doesn't make any sense.
You can drive directly the mute using the output from the Arduino. The mute minimum/maximum voltage it is 2 to 5 volts. I do not see any problem. If the Arduino have D/A you can send an output of 2 volts. That is the beauty of using a micro.
hey tauro
im worried the mute pin might draw to much power from the arduino. the I/O pins of the arduino are limited to 40mA / 20mA reccommended!
and for some reason i cannot get the mute pin to work anyway, using a 5v battery to mute pins and ground. weird huh?
plus i need a latency free mute switch, and im not sure if the LM1876 mute pin works instantly... does anyone have experience with this chips feature?
If you check the mute in the schematic Figure 6. LM1876 you can see that the mute goes to the base of a transistor so it would not required a lots current to enable or disable the mute using the output from the Arduino. I will use the output with no problem.
Just to let you know that I am using a NANO micro to control the speakers output and also the mute of my LM3886 amplifier. Since the mute in the LM3886 it is negative and for isolation I am using a solid state relay LH1546. It worked with no noisy whatsoever.Just clean in the ON/OFF.
try a 10k resistor between the arduino and the LM chips. that should sufficiently limit the current.
you could always use some small signal transistors as switches connected to the arduino to mute the chips. plenty of examples on the arduino web forums for that!
Attached is an schematic on to do the input selection switching. This is an idea how to do it. It use 2 I/O pins from the Arduino micro.
At the beginning I was unable to follow the circuit since you over look that pin 1 it is the one with the square. You have to turn around the socket or leaving it like it is just cosmetic. Are you trying to switch audio no? I was thinking that you was trying to mute the LM1876. The NJM2521 what it does is to select one output from three inputs. I just want to verify that were are in the same track.
