Ever think of building a Cornu Spiral horn? Now you can!
Cal & XRK,
I'm getting ready to start a pair of Cornucopya's with the Altec Lansing 405A drivers I have. Near as I can tell, the 405A is close to the same size as the FF125wk, although when I measure the cone, it looks to me like 8.5 cm dia. pistonic size, or an S(d) = 57 cm**2, compared to the FF125wk spec of S(d)= 66.5 cm**2.
When I plotted the spiral (which Cal appears to have used at the start of this thread) for a 27" horn, I find a CC measuring 4.5" x 5" with throats about 17mm wide. If I use a channel depth of 5", this comes out to 43 cm**2 total for the two throats.
How do I get the total throat area up closer to S(d) which IIRC is what you recommend? Shrink the CC a bit?
Thanks, Jim
Jim,
There are several ways to expand the throat area: custom draw the channels to have a wider throat if you want to keep external dimensions the same; increase depth of channel, or grow whole cabinet. Note that some compression is ok, if ratio of throat area to Sd is greater than 75%, it's probably ok. For low Qts, high Bl drivers with low xmax, you might want more compression to load driver and reduce excursion. It should be modeled - a simple model in HornResp with a conical horn for first section to exponential horn near mouth wirh
appropriate dimensions for driver chamber will tell you a lot about excursion of cone.
If you are using the plan from planet10's pdf diagram, I think the the throat width is 0.9 in for the 27.6 in cornu. That is 2.3 cm wide not 17 mm wide. This gives a throat area of about 57 cm^2 for a 5 in deep channel. This about a perfect match for your driver if you wanted no compression. You could probably go as thin as 4 in and be ok.
What are the T/S params for your Altec driver?
Good luck!
Xrk971
Closet door stereo 😉
I was wondering what a Cornu horn would look like if we were to actually use the true Cornu function which is also known as a clothoid. ...
Nice work. Did you notice something something pretty significant? The resulting horns closely follow an exponential length/area law. You can model single-spiral (divided 4 ways) Cornu horns in Hornresp using a single exponential section, and the multi-length horns like the one in your post in AkAbak. I'll modify (simplify) my AkAbak model accordingly.
Don,
I have re-spun the cornu generator to make a reasonably sized horn than I can build: 24 in x 3.5 in deep, driver chamber cross sectional area of 148 cm^2, chamber volume of 1312 cm^2, channel lengths of 147 cm and 104 cm long, the throat cross sectional area (both) is 31.3 cm^2 - which will provide a mild level of compression for the TC9FD Sd of 36.4 cm^2. The horn mouth area is 2168 cm^2 I am still doing the bifurcation. See attached plan. I did a simplistic sim in HR for each horn independently and then combined them after the fact to see if the bumps and valleys help cancel out. I still plan to to use the TC9FD with this. I am still unclear how to specify the channel width as function of distance in Akabak for the true cornu. Thanks for trying this in Akabak.
Xrk971
Jim,
Good luck!
Xrk971
Thanks Xrk971!
All I know about the Altec 405A is what I found on the Altec site--which is nearly useless. And I haven't the tools to measure the T/S parameters. Which is why I want to try a quick, inexpensive, flexible design.
Cheers, Jim
