Class D Amp with LM566, LM393 and 2XIRF530
D200 +/-75V
With +/-75V DC rail voltage 2k2/2W are very hot, but it's ok. BD241C must have heatsink.
Mile ,
This is your own amp ?
which mosfet did you use for +/-75v ? how was the sound and quality then ?
it's beter to use 3W instead of 2W !
i found some amps on Russian language forums , with LM311 instead of TL081 and some difference in design , did you see them ?
Mile ,
I use IRF640N for test with 8 ohms speaker, sound is hi-fi quality and mosfets is just warm without heatsink (work at over 100W ).
Russian amp is UCD topology and D200 is IRAUDAMP1 topology.
Thanks Mile ,
where can i find difference between this two topologies ? I really want to understand how they work...but i cant find a short and good article about this..if you don't mind , please give me some lessons.
i'm going to build this amp , as soon as possible !! :rolleyes:
IRSound
Irsound could share these russian page links? thanks.=
Hi Exflaco , i found that picture in google image search. i don't remember which forum was it. :(
but i think mile upload their schematic before. LM311+74AC00+IR2110
he changed modulator section with mackie. i upload those schematics for you.
why you aren't try D200 ?
mile , i forgot to ask another question..why you aren't put large electrolyt capacitor behind fets ? because of bus pumping effect..IRF always use this caps in their designs. or other project like irs series , etc.
IRSound
IRSound
With my PCB design no need for large electrolyt capacitor behind fets on pcb just in PSU, and I use 470nF and 2X 220nF on pcb.
