UCD 25 watts to 1200 watts using 2 mosfets
Hi all pls help . The irs900d i made , i tested with +/-45vlts everything was o.k except ir2110 heating which was solved by a small heatsink . When i added the voltage to +/-75vlts the amp works for a few minitues then distorts badly all channels behave the same. the components are exactly the ones posted in irs900d . When i reduced the voltage to +/- 39vlts all channels are working o.k .
The amp has 3channels , my inductor is etd42 20turns . Outputs are irfp250n with 100ohms gate resistor . the aux voltage i used irf640 for each channel to produce the +12vlts the main capacitor is 100vlts x 1000uf x 4pieces.
hi stewin,
irs900d is using 2inverter buffer (cd4049) pls change the schemantic pcb layout to 3 inverter buffer stage.
thiechay 900d version
Hello all Diyer 🙂
This my new class D , and i 'll checking it soon 🙂 .
hi all has anyone tried thienchay irs900 amps with high voltage like +/-75vlts and above?
  • IRS-900D _ Overlay_ checked.pdf
  • IRS-900D _ PCB 2 thienchay_2.pdf
The resistor for oscillation in irs900 is the one 1k between the two 1nf near the amps input.the gate resistors has to be 100ohms if you are using irfp250n . The inductor try 80uh .the irs900 is not friendly to high voltage . Have fun.
By the way hadi , what voltage did you use with your aud600, and how was the sound quality?
Hi sir stewin
some one say to me sir is used for soldier and commander 😀
i change some resistor for + - 30 VDC
i use to + - 50 VDC too
sound is very good in quality and power but i dont have power full smps and i realy need that
sir manoj amp is very compelet in protection and every things but it was a littel big
creat ver 1.0
it was work so good
i have T106-2 and 0.8 mm wire
how much turn for IRS series dear friend ?
have nice time🙂
Cant buy right Mosfets because not stock by local supplier, its X-mas time
order takes long time and I want test IRS4K5 now
Have only in Stock IRFP460
IRS4K5,....with IRFP 460 what will happened for test ?
Music comes out or amplifier not working or firework ?
