Hypex Ncore
Just wanted to follow up from a prior post regarding issues I having with my NCores. I'd been away for a couple weeks and wasn't able to get around repairs until recently. An employee at Hypex suggested a possible issue with my speaker posts not being isolated properly. I believe this is where the issue lied. Another problem may have been bad contact due to the binding posts being annealed. Lastly I purchased one of these Line-R 1200VA Automatic Voltage Regulator suggested by Bavmiike. In one fell swoop made all changes and hooked them up and they work perfectly. Furthermore I believe the apc voltage regulator has improved them to worthwhile degree. I sexond Bavmiike's observations and recommend it for digital components with SMPSs. Thank you for the suggestions and thought and also thanks to the people of Hypex in their ability to isolate the issue from fairly junky iphone pictures.
I'm glad it worked out for you. It was the best $50 I've spent in my system by far.
Some nCore users have reported excellent improvements in sound quality when coupling a DAC to the nCore via a tranformer of some type. Output transformers in the DAC, TVCs, and input transformers in the amp have been reported to result in sound quality improvements.
I noted that one DAC I tried with the nCore produced a course grainy noise floor (still only audible with an inch from tweeter), and have come to suspect that the nCore is sensitive to RF on its input (as are many class D amplifiers).
So, as Julf is pointing out, there may be additional benefits to reducing the gain of the Mytek DAC via a transformer which would justify the high price. Also, going amp direct, using a transformer to step down the voltage a little increases the current drive vs using a resistor based solution, and I find having higher current availability is a good thing when driving amplifiers directly as well.
My AN DAC kit 4 with (balanced) output transformers combines extremely well with the Ncore's! (in my opinion) 😉
really, that's it?
I originally installed a 9V battery without giving any thought to how much current it was using. The next day when I came home from work both my amps were powered on because the batteries died, it had not even been 20 hours and very well could have been much less since I was not home to see when they actually died.
Not sure exactly what the mAh is on the 9V I used but i'd say for a typical alkaline it's somewhere between 400-500mAh. At only a 5mAh draw the batteries should have lasted 3-4 days.
I was assuming it would be much higher.
Pops at turning off
Hi All,
My nc400 build is up & running sounding great.
I just have an issue with loud pop when turning off the system.
What makes this a bit more complicated, is that everything is build together into a big single chassis, including the DA converter. There only input is optical link to the dac, and the only output is the amplifier output.
The link between the dac - line stage - amp is all balanced.
The nAMPON connectors are connected to the ground of the line stage output (same as to the shield of the input cable of the nc400).
When turned on everything is ok, there's a very slight pop, but it's not even noticable if one does not look specifically for it.
The DC offset on the line stage output (between cold and hot) is 0.1-0.2mV according to my multimeter, hopefully it does not cheat too much at these levels.
The DC offset on the amp output is varying a bit, but not more than 20-30 mV.
(I'd expect that dc at amp output = amp gain x line stage dc, so around 2-3mV offset at the amp output. Probably a measurement artifact only, or not fully precise trimming of the amp. This is not so bad, I guess, anyway.)
However, when I turn off the entire system with the only switch of the chassis, I get a very loud pop.
I made experiments powering them separately, leaving dac+line stage powered, and in this case there's only a very slight pop when powering down the amps only.
So my problem is, I do not want to separate the dac and the amp, as the goal is keeping it compact, and would like to keep only one switch.
Adding a small microcontroller sequencing the power down, would be a possible solution, but that's still not perfect - one can accidentally turn off at the power distributor, blackout, etc. This is probably paranoid a bit, but I like safe designs..
Do you have any idea how could I manage this?
Thanks,
igy
igy, i think that the ncore must first be off before the power goes off. You can try a 230VAC relais coppled to the mains switch with the contact on the amp on/off(J9 pin3)and ground (J9 pin4)of the nCore. When you turn off the mainswitch the relais contact turns the ncore off before the powersupply loses his voltage. Normally then there will be no plop.
Version control.
I just purchased a third amp/power supply and notice they are version 3 and four respectively. Optically they look the same, except the power supply, where there has been the addition of some hardware on the board. I will use this as the center channel, but wonder if and what difference the hardware changes make.
Thank you
Version control.
Thank you
Nice to see versions. Can you post a pic of the SMPS?
Please see the attached photos. I know they are terrible photos, but you can see the first one is version 1. Close to the center, you can read on the board "C23". Then, on the second is version three. You can see there is an extra "box" on the board, where it used to say, C23. I can also tell you that when you power them up, the new one takes about a second longer to click on. No idea on heat or sound, yet...
The third photo is me showing off. That is my three channel amp. any suggestions?
SMPS standby setup help
I have a three channel Ncore amp and I just leave the unit on all the time. However, the heat buildup is too great, almost too hot to touch. I want to setup the SMPS to go into standby. I know I use pin 1 on J1 connector of the SMPS and need build/buy a trigger circuit that applies a constant voltage, to keep it in standby mode? I also understand that once the SMPS is in standby, it will send the amp portion into standby, within 15 min? My question is, how do I go about setting up this circuit. Any help would be great. I have never build something like this.
I felt the same about wanting to power down the smps even though everybody said it was fine to leave on and that it didn't use much electricity.
I wanted to use the standby rather than powering down my amp at the 120V main switch I put on the back, but since the required voltage isn't available inside the amp I bought a small 2 or 3 watt 120VAC -> 9VDC transformer/rectifier from digikey and now just use the illuminated push button switch I have on the front of the amp to power it on and off. I have not noticed any negative effects with regards to the sound with having a small transformer in parallel with the supply power.
Well glad too hear I am not alone. There is just no way that you can leave these on, with three in one case. Its just too hot. The case is all aluminum, vented on the top and bottom, but it just does not matter.
I will admit that I don't fully know what I am looking for. I have done a lot of firsts with this project and have acquired a lot of parts, tools ,etc, building these amps, many in error. I get that you have a device that reduces a 120VAC current to a 9VDC. This connects to the IEC and then to pin one on J1, via the power button. I am just not sure what I am looking for on Digikey, despite a couple hours of searching. Any help would be great.
Thank you
I purchased a board style converter and just used some adhesive velcro to mount it in my chassis. You can just solder some wire to the pins or just use a crimp, it's not really a critical connection and worked just fine without mounting to a pcb.
Power Supplies - Board Mount | AC DC Converters | DigiKey
From there you can use the filters to select what voltage output you want (if I recall you can use anywhere from 3.3 to 12V, I chose 9), and what kind of current output you require on the secondary.
There are also the off board converters
Power Supplies - External/Internal (Off-Board) | AC DC Converters | DigiKey
Though I didn't have too much luck searching through all those.
This is the exact one I bought..
VSK-S3-9U CUI Inc | 102-1803-ND | DigiKey
I realize after reading this tread over again, that I can use a 12v trigger. My processor has a 12vdc trigger. Is there any reason that this won't work? Its a programmable trigger. If not, could you help me with this? Spent an hour on Digikey, and couldn't find it.
Thank you
It would work but would totally depends on the processor and how programmable it is.
Most equipment sends 12V when it is on. In your case you would need the processor to output 12V when it is powered down and disengage the 12V when you turn the processor back on
