900W H-class PA Amp with Limiter
hi apex sir ,
is this three step power supply correct?,
compare to ur schematic.
The 50Vdc from 35Vac transformer varies with mains voltage. This applies when regulation ~4%
It can be as low as 48Vdc and as high as 53Vdc
If you double this from a 70Vac tapping then the maximum voltage could be as high as 106Vdc.
If regulation is >>4%, then the worst case highest voltage can be >>100Vdc
I would not do that !
h900 v.2
Hello Rizqi,
Thanks.. This design have not been tested yet i'm still trying to find some error before i etch, but you can also review and let me know if you found any mistake so i can correct the error.
Send me your email add so i can forward you the sprint layout file.
i've cek your layout🙂, thats nice n good layout, so there are more space for some component. your layout has true.. please send to : ugho_mdlx@yahoo.com
good job sir,...
thanks n regards😉
