looks even cleaner now
but your ground lines....
actually, I think ground lines should be even bigger sized than the supply rails
looks like theres plenty of empty board space for it now
turn the supply caps , and let the ground line go all the way up to output line
you dont need that long thin ground line for output zobel either, just connect it to ground
make the ground one single line, and as big as possible
its not a digital curcuit, its a high current thingie
Hello
Yes Alex that is much better.
Wahab is right about the mosfet pin. If you can take one more advise.
I would go outside with the PS voltage to the mosfets both side.
I scratched one side like that, that case we could get read of that two jumper..
You have room enough to do that that way. When you invert the mosfet pin 2 & 3 you will gain some room with that to..
Thank you Alex
Greetings Gabor
Thank you Alex
Greetings Gabor
If I have forget something please tell...
yes, noone responded, but I still think you should connect speaker ground right next to board ground spade
as should ground from frontend aux supply, and signal ground
btw, speaker negative is signal ground just as well as your source
plenty of space for another connect spade(or two) beside the supply ground spade connect
then you can connected all grounds there
it is the right place for it ...especially if main supply caps are further away
No I don't think so , spk negativ must go to star ground , INHO .....yes, I think speaker ng/ground should connect right next to board ground spade, and signal ground
plenty of space for another spade connector beside the supply ground
That s the best solution i think.
Also , there s a 1R (R34) resistor that is missing in the PCB between the signal
and power ground.
where do you connect ground from front end aux supply ?
ah !
and power ground.
ah !
ah !
Neverless , there s two wires from the PCB that goes to the ground star point ,
one originating from PCB power ground and the other from PCB signal ground.
This resistor is just here for redundancy.
Hello
Here is my test board so called "art work"
I upgrade it up to the last mod, I ad the Q20 and the two C12/13 caps.
Since all hand drawn on my computer paint program I do not have silkscreen like Alex who is great and talented with software design.
I did tried one time to use some free software, I didn't succeed so I keep draw my layout by hand.
These is hot iron transfer friendly at least...
Alex design is so beautiful I would pay to get it on a professional made PC board.
In case someone want to go ahead use these as a test boards please open with the paint program, after page set up, chose 90% and print.
If you need the color code I use from the components I already posted but I will help with.
Greetings Gabor
Greetings Gabor
- All Hitachi Lateral Fet amplifier for DIY described by Paul Kemble
